Same question myself. Inovelli/Minoston modules fight over Manufacturer ID 0312. Just need to know how to get to the config files I guess to adjust this.
All Inovelli products should currently be supported by default (aside for the fan controller), so you don’t need to install any config files. The instructions Inovelli provides are for the old zwave integration.
Scenes are available using the ozw.scene_activatedevent.
Do you know what this scene count is in the user values of openzwave beta?
Weird things are happening. So If I setup node red to listen for ozw.scene_activated and I press down 3 times on the switch, i see it in debug. But if I then press up once (light turns on), and then press down 3 times again, no scene is registed in debug.
BUT
if I press down twice, that scene is registered. And then if I press down 3 times again, the scene is registered.
I then noticed these user values seem to be changing and wonder if thats conflicting or something.
Its almost as if the scene I am trying to activate is already in Scene 1 or Scene 2, it will not activate. I must turn on a different scene, and then go back to the one I really want to do. I dont get it.
