I’ve been watching the OZWave beta attentively as it promises to solve a huge issue for me which is every time I restart the zwave network needs to restart.
I discovered that the way OZW does this is by relying on MQTT server for comms.
Given this, I wanted to confirm that the intention is to run an MQTT server separate, outside of HA and not with the MQTT addon?
For all stuff related to HA I have tended to run it as addons if avail. Eg. Node red, even though I could run it in its own container. Logically I like the grouping.
However in order for the zwave network to not restart on HA restart with OZW do I need to run a separate instance of MQTt? Or is that irrelevant?
