Since multichannel communication is supported, the root device isn’t the only end point
i’m beginning to think I never will get this to work. do you think i should removed the node and add it again
Associations are stored in the node, so you have to remove them, re-including the device won’t help.
When i turn on the device from HA i have debugged the Payload in node-red and i think it is wrong, but i am a noob to MQTT but i will like to learn some more about it so i know what to do and look for.
Can anybody help me understand this?
{ “Label”: “Instance 2: Switch”, “Value”: false, “Units”: “”, “ValueSet”: true, “ValuePolled”: false, “ChangeVerified”: false, “Min”: 0, “Max”: 0, “Type”: “Bool”, “Instance”: 2, “CommandClass”: “COMMAND_CLASS_SWITCH_BINARY”, “Index”: 0, “Node”: 27, “Genre”: “User”, “Help”: “Turn On/Off Device”, “ValueIDKey”: 457785376, “ReadOnly”: false, “WriteOnly”: false, “Event”: “valueRefreshed”, “TimeStamp”: 1608755130}
