OpenZwave integration
Hi All,
I’m new to openzwave and after en few hours of trying and searching on the community and google i cannot get the integration part working.
The OpenZwave supervisor add-on is running and is see the OpenZWave instance on MQTT with instance id 1 (from MQTTExplorer)
When trying to open the OpenZWave (Beta) integration i get the message:
We couldn’t find an OpenZWave instance. If you believe this is incorrect, check your OpenZWave and MQTT setups and ensure that Home Assistant can communicate with your MQTT broker.
I’m also using mqtt for zigbee2mqtt.
Can anyone point me in the right direction?
I’m currently experiencing the exact same problem. Did you ever figure this out?
Well i removed all zwave related components.
Deleted zwave related files from hassio config folder.
Restarted hassio and installed the openzwave add-on from supervisor and afther that the integration.
After that It worked
