When I turn the device off in home assistant, the message is received and aknoleged on my mqtt broker.:
If i quickly (before the device automatic in home assitant is on state again) turn on the device then the mqtt state is again received and the devices turns on.
Verify a difference between ozw-admin and the data as shown in MQTT. If there is you can report a bug to qt-openzwave, otherwise this will need to be reported as a HA core bug.
Same here, exact same problems as described above as well. I’m running all the latest integrations and Home Assistant versions with an Aeotec Z-wave stick and Fibaro dimmers. I don’t want to use polling as the zwave status is already correctly displayed in OZW-admin so checking the Z-wave device isn’t necessary and will create latency on the mesh network.
This is simply the HA interface not reflecting the correct status of the MQTT / Z-wave devices. Did anyone find a solution for this since it’s happening so often it’s making my entire automations unreliable.
I got it fixed.
Had many of my sensors added as secure devices, removed those and readded them as insecure devices. No only my fibaro (cant be added insecure) and my locks are secure added.
Delay is now under 1 sec and status is now working perfect again.
