Hi all. Is there a known issue with RF-Link and Home Assistant 2022.10.3, Supervisor 2022.10.0, Operating System 9.2?
I updated to OS 9.2 earlier this evening and now RF-Link no longer works. Errors in logs recurring at every attempt to use RF-Link and something like this error during decode of data, invalid data: ��a�x�� (hieroglyphics appear exactly like that in the logs).
I reverted to OS 9.1 and it was still problematic.
I then discovered that the USB port assigned to the RF-Link had changed from ttyACM0 to ttyACM1. I switched it back and it worked again.
Note that the setting is a manual entry in configuration.yaml and I did not edit it, nor did I or anyone else go near the HASS server (it is in a locked cabinet).
I have again upgraded to 9.2 and it is working. USB port did not change this time.
