Another crash
Logger: homeassistant.helpers.entity
Source: components/filesize/sensor.py:50
First occurred: 10:27:22 (95 occurrences)
Last logged: 11:14:22
Update for sensor.home_assistant_v2_db fails
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 263, in async_update_ha_state
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 456, in async_device_update
File “/usr/local/lib/python3.8/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/filesize/sensor.py”, line 50, in update
OSError: [Errno 5] I/O error: ‘/config/home-assistant_v2.db’
Source: helpers/storage.py:225
First occurred: 10:27:26 (8 occurrences)
Last logged: 11:12:26
Error doing job: Task exception was never retrieved
File “/usr/src/homeassistant/homeassistant/helpers/restore_state.py”, line 175, in _async_dump_states
File “/usr/src/homeassistant/homeassistant/helpers/restore_state.py”, line 161, in async_dump_states
File “/usr/src/homeassistant/homeassistant/helpers/storage.py”, line 143, in async_save
File “/usr/src/homeassistant/homeassistant/helpers/storage.py”, line 216, in _async_handle_write_data
File “/usr/src/homeassistant/homeassistant/helpers/storage.py”, line 225, in _write_data
File “/usr/local/lib/python3.8/os.py”, line 223, in makedirs
OSError: [Errno 5] I/O error: ‘/config/.storage’
Logger: aiohttp.server
Source: components/recorder/util.py:80
First occurred: 11:11:14 (8 occurrences)
Last logged: 11:11:35
Error handling request
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py”, line 2339, in _wrap_pool_connect
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/pool/base.py”, line 364, in connect
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/pool/base.py”, line 778, in _checkout
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/pool/base.py”, line 495, in checkout
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/pool/impl.py”, line 239, in _do_get
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/pool/base.py”, line 309, in _create_connection
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/pool/base.py”, line 440, in init
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/pool/base.py”, line 661, in _connect
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/util/langhelpers.py”, line 68, in exit
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/util/compat.py”, line 178, in raise
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/pool/base.py”, line 656, in __connect
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/strategies.py”, line 114, in connect
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/default.py”, line 493, in connect
sqlite3.OperationalError: unable to open database file
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py”, line 418, in start
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py”, line 458, in _handle
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py”, line 119, in impl
File “/usr/src/homeassistant/homeassistant/components/http/real_ip.py”, line 39, in real_ip_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 73, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 127, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 129, in handle
File “/usr/src/homeassistant/homeassistant/components/history/init.py”, line 499, in get
File “/usr/src/homeassistant/homeassistant/components/history/init.py”, line 525, in _sorted_significant_states_json
File “/usr/src/homeassistant/homeassistant/components/history/init.py”, line 141, in _get_significant_states
File “/usr/src/homeassistant/homeassistant/components/recorder/util.py”, line 80, in execute
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/ext/baked.py”, line 445, in iter
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/query.py”, line 3524, in _execute_and_instances
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/query.py”, line 3539, in _get_bind_args
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/query.py”, line 3518, in _connection_from_session
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py”, line 1138, in connection
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py”, line 1146, in _connection_for_bind
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/session.py”, line 433, in _connection_for_bind
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py”, line 2305, in _contextual_connect
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py”, line 2342, in _wrap_pool_connect
File “/usr/local/lib/python3.8/site-packages/sqlalchemy/engine/base.py”, line 1584, in handle_dbapi_exception_noconnection
sqlalchemy.exc.OperationalError: (sqlite3.OperationalError) unable to open database file
(Background on this error at: Error Messages — SQLAlchemy 1.3 Documentation)
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:36
Integration: Recorder (documentation, issues)
Error executing query: (sqlite3.OperationalError) unable to open database file (Background on this error at: Error Messages — SQLAlchemy 1.3 Documentation)
Source: components/http/static.py:39
First occurred: 11:20:51 (36 occurrences)
Last logged: 11:21:43
File “/usr/src/homeassistant/homeassistant/components/http/static.py”, line 39, in _handle
File “/usr/local/lib/python3.8/pathlib.py”, line 1403, in is_dir
File “/usr/local/lib/python3.8/pathlib.py”, line 1194, in stat
OSError: [Errno 5] I/O error: ‘/usr/local/lib/python3.8/site-packages/hass_frontend/static/mdi/836998573a5d3d0c4d80f23e8657af349b083809.json’
