OPNsense seems to be blocking Update Channels
Dear Home-Assistants,
I seem to have a issue with my OPNSense Firewall.
I also got a PFsense and got the same issue:
After the Integration of the Firewall I can’t update Zigbee2MQTT and or Home Assistant Core/Supervisor.
(see screenshot below)
Obviously I watched the logs while clicking on Update but it won’t work.
Right now the firewall is on allow any all because I did not configure it to the bone.
Anyone else got the issue and could get rid of this?
Best regards
Hello red.hood,
Well DNS has to be working properly and the instance has to be able to get to the internet as normally expected, so this is likely something with the way you have this set-up.
What you are doing is definitely Advanced mode and
I think i found my mistake …
I set up AdGuard before i installed the Firewall and had another IP Adress for my Home Assistant.
After the IP-Adress Change i forgot to change the DNS of my Home Assistant to the new IP … Now it works again.
Well, adguard & pihole is a mistake in itself, but you do you.
It causes more problems here than most other things.
