I just took a look at trigger id’s thinking I could simplify my automations. So instead of a separate automation for every action I can combine them.
Most of my automations are pretty “binary”, for example, turning on a light when there is movement and x amount of lumen. And turn off the same light when there is no motion for x amount of time.
Before my automation looked like this:
- id: licht_kantoor_aan
alias: Zet het licht aan in het kantoor bij beweging
platform: state
entity_id: binary_sensor.motion_kantoor_home_security_motion_detection
to: 'on'
condition:
condition: numeric_state
entity_id: sensor.motion_kantoor_illuminance
below: 25
service: light.turn_on
entity_id: light.kantoor
- id: licht_kantoor_uit
alias: Zet het licht uit in het kantoor bij geen beweging
platform: state
to: 'off'
for:
seconds: 600
service: light.turn_off
Now when utilizing trigger IDs it looks like this:
- id: licht_kantoor_aan_uit
alias: Zet het licht aan en uit in het kantoor
- platform: state
to: 'on'
- platform: state
to: 'off'
for:
seconds: 600
- choose:
- conditions:
- condition: trigger
- condition: numeric_state
below: 25
sequence:
- service: light.turn_on
- conditions:
sequence:
- service: light.turn_off
Both cases work just fine. The advantage is that I now only have 1 automation to control the light. But the downside if that my code is actually 8 lines longer then the two separate automations.
Can my code be compacted while still retaining readability? Especially the choose actions takes a lot of lines.
