Optimizing my picture-elements dashboard
Hi !
I have a picture-elements based dashboard, that uses the states of my philips hue lights to render a floorplan of my place.
Currently, each light is an independant card, with my setup looking like that :
- type: custom:config-template-card
  entities:
	- light.chambre
  element:
	type: image
	image: /local/ui/floorplan/lights/chambre.png
	action: none
	entity: light.chambre
	tap_action:
	  action: none
	hold_action:
	  action: none
  style:
	height: 100%
	left: 61.3%
	top: 55%
	width: 72%
	mix-blend-mode: lighten
	filter: >-
	  ${ "hue-rotate(" + (states['light.chambre'].attributes.hs_color
	  ? states['light.chambre'].attributes.hs_color[0] : 0) + "deg)"}
	opacity: "${states['light.chambre'].state === 'on' ? (states['light.chambre'].attributes.brightness / 255) : '0'}"
  entities:
	- light.chevet
  element:
	type: image
	image: /local/ui/floorplan/lights/lampe_globe.png
	action: none
	entity: light.chevet
	tap_action:
	  action: none
	hold_action:
	  action: none
  style:
	height: 100%
	left: 61.3%
	top: 55%
	width: 72%
	filter: >-
	  ${ "hue-rotate(" + (states['light.chevet'].attributes.hs_color
	  ? states['light.chevet'].attributes.hs_color[0] : 0) + "deg)"}
	opacity: "${states['light.chevet'].state === 'on' ? (states['light.chevet'].attributes.brightness / 255) : '0'}"
As you can see, with only 2 lights shown here, it’s quite redondant when most what’s inside of the “custom:config-template-card” is the same, except for the entity, the image directory, and the filter/opacity style.
I was wondering if there was a way to make a template to make my ui-lovelace.yaml less cluttered and redundant ?
Thank you for your help !
