I recently upgraded from an older version (0.6x or 0.7x) to the current 0.8x. I don’t need any authentication because I use the UI only on a trusted network. I have seen that the option to skip authentication was completely removed (https://github.com/home-assistant/home-assistant/pull/18854/files).
Since my network is trusted, I enabled the “trusted network” authentication provider and created a single user. Unfortunately the login dialog still appears and asks me to select a user. It would be nice if I could entirely skip it by an option that tells the provider to always select a particular or the 1st/only user and to proceed without interaction.
