i am trying to write a blueprint with the following trigger:
- platform: state
entity_id: !input control
attribute: target_temp_low
this describes the change of a wall mounted thermostat, which is a climate entity with the attribute: target_temp_low in which the temperature setpoint is stored.
This works, however not every room of my has a wall mounted thermostat, some only have an external temperature sensor, so i want to make the “control” input to be optional.
I tried the following which unfortunately doesn’t seem to work:
trigger_variables:
control_trigger: !input control
value_template: "{{ state_attr(control_trigger, 'target_temp_low') }}"
the input for the “control” entity looks like this:
control:
default:
selector:
entity:
filter:
- domain: climate
What am i doing wrong? Any help is much appreciated.
