I have a blueprint for turning on lights (switches) at sunset.
It includes settings for sun elevation and between two times.
Currently I also have a hard coded condition for my alarm to be deactivated.
Now for the problem. Some of my lights should only turn on if alarm is deactivated but some lights should not care if alarm is on or off.
So, I would like to include a boolean varable to decide if this condition should be used or not.
Something like “Only turn on if alarm is deactivated”.
When used as automation, if boolean variable is set, this condition should be used:
condition: state
entity_id: switch.alarm_active
state: 'off'
And if boolean variable is not set, the condition should not be used at all.
Here is my current blueprint:
blueprint:
name: Pluggar - Tänd - Kväll
description: Slå på pluggar vid solnedgång
domain: automation
input:
# Variable for identifying the switches to act upon
target_switch:
description: Plugg eller pluggar som ska slås på vid solnedgång
# Use a selector, to pick the switches
selector:
entity:
domain: switch
# Variable for sun elevation offset
elevation_shift:
description: Solens vinkel ovanför horisonten. Ett positivt värde tänder tidigare medans ett negativt värde tänder senare.
default: 0.0
# Use a selector, to set the time shift or offset
selector:
number:
min: -3.0
max: 3.0
mode: slider
step: 0.5
# Variable for time window
time_after:
selector:
time:
time_before:
selector:
time:
# Prevent the automation from running concurrently
mode: single
# Define the variables used in the action section
variables:
target_switch: !input target_switch
# Define the trigger for the automation
# Using the state of the sun to act as the trigger
platform: numeric_state
entity_id: sun.sun
attribute: elevation
# Can be a positive or negative number
below: !input elevation_shift
# Add a condition to ensure that this only triggers near sunset, in the evening
condition:
# Check that it is after sunrise
- condition: sun
after: sunrise
# Add a buffer to be sure
after_offset: "01:00:00"
- condition: time
after: !input time_after
before: !input time_before
- condition: state
state: 'off'
# This section will take action on the switches, and turn them on
# A very simple structure of turning on the selected switches
- service: switch.turn_on
target: !input target_switch
