Optional conditions?
I come from a Control4 background and in Control4 I can nest IFs. An example
If motion not detected
→ turn off light
If TV on
→ turn off TV
This essentially says when motion not detected turn off the light… optionally also turn off the TV if it is on.
So I have this existing automation and I want to put in a similar conditional that says if the TV is also on, turn it off without having to create a whole separate CHOOSE section. Is this possible? Or am I creating a third Choose?
alias: Front Parlor Occupancy Monitor
description: ''
  - platform: state
    entity_id: binary_sensor.front_parlor_foyer_occupancy_monitors
  - platform: event
    event_type: timer.finished
    event_data:
      entity_id: timer.front_parlor_occupancy_timer
condition: []
  - choose:
      - conditions:
          - condition: state
            state: 'on'
          - condition: state
            state: active
          - condition: trigger
        sequence:
          - service: timer.cancel
            data: {}
      - conditions:
          - condition: state
            state: 'off'
          - condition: state
            state: idle
        sequence:
          - service: timer.start
            data: {}
      - conditions:
        sequence:
          - service: rest_command.deshler_front_parlor_unoccupied
            data: {}
    default: []
mode: single
You could have an entirely separate choose block that turns it off if it’s on.
Oh, and you can nest both choose and if.
Note my request to NOT have a separate choose block. I understand how to do that.
How does nesting choose and if work as Google and the docs haven’t turned anything up?
You put the nested choose inside the sequence. Just like you would in a script sequence or action section of an automation.
Are there syntax examples somewhere?
All you need is an example of a choose
Ok, I see what you’re after. I think the easy answer here is yes you can do it, but it isn’t significantly easier/less code than a separate choose block so I might as well copypasta a new choose block and add a condition. Thanks!
