I’m tryting to create a blueprint for some status displays, which I have in multiple rooms.
For context
I have KNX MDT Glastaster and use exposed input_text
entities to send data to them. The text should change based on different external factors, e.g. show the departure time of the bus, when we have breakfast, show the radio station, artist and title when music is playing, and in other circumstances show sensor values like indoor and outdoor temperature, humidity, etc. The automation triggers on state changes of any of these sensors and updates the according input text
. This part is not the problem and works fine in an automation for a single display.
Now I want to build a blueprint out of that, so I can reuse it for all displays. But I dont have every type of sensor in every room, also not every room has a media player. So I want to use the blueprint to select the relevant entities for the specific room.
The question
Is it possible to have optional inputs for a blueprint, that are then used as entity in the state trigger? Or is there any other way to achieve a similar result?
Here are two examples for triggers of two seperate automations, with different sets of sensors:
- alias: related object changes Esszimmer
platform: state
entity_id:
- sensor.ez_temp
- sensor.ez_humid
- media_player.ez_denon
- alias: Related object changes Wohnzimmer
platform: state
entity_id:
- sensor.wz_temp
So I want to create both triggers in two sperate automations from the same blueprint (with different inputs obviously).
Here is the basic setup of the blueprint:
blueprint:
domain: automation
name: KNX Glastaster - Statusdisplay
input:
temp_sensor:
humidity_sensor:
name: Humidity sensor (Optional)
default: ""
media_player:
name: Mediaplayer (Optional)
default: ""
variables:
temp_sensor: !input temp_sensor
humidity_sensor: !input humidity_sensor
media_player: !input media_player
And here are some of my attempts to define the trigger in the blueprint, none of them are working for more or less obvious reasons.
(I) No Default Value for optional inputs
Omitting the default = ""
parameter for optional inputs leads to automations not even initialising, if the respective input is missing. Therefore all optional inputs have to be either set, or have a default value set as done in the example above.
(II) Using !input in the trigger
Defining each entity via !input
works generaly fine, unless the input
is empty.
- alias: Some related object changes
platform: state
entity_id:
- !input temp_sensor
- !input humidity_sensor
- !input media_player
The resulting ""
breaks the automation.
platform: state
entity_id:
- sensor.wz_temp
(III) Template for eliminating emtpy entities
In the blueprint:
platform: state
entity_id: "{{ (temp_sensor,humidity_sensor,media_player) | select() | list }}"
This gets me this trigger in the finished automation, which does not work, as templates are not allowed in the entitiy_id
platform: state
entity_id: >-
| select() | list }}
As you can probably see, I am out of ideas. It tried some other things aswell, but they were even more desperate and ridiculous then the given examples, therefore they are not worth documenting at all.
Has anyone accomplished something like this? Or has any idea how it could be done?
Thx
CanisLupus
