Options for best Spotify browsing in HASS
So I’ve been using spotify connect with the spotify media player, via snapserver. All works fine. But the one thing that I was disappointed about is the browse mode. So typically I see this
when I start browsing. But are there other options ways of browsing. Not to mention once you start playing something from a playlist you can only skip, you can’t see the entire playlist unless you go back to the beginning and start browsing again.
I also installed Music Assistant which seems to have a much deeper integration but the problem with this is - it doesn’t connect to snapserver… I’ve checked the github for both snapserver and music assistant it doesn’t look like a integration is available at the moment.
What other options are available? What are other integrations people are using?
