hey guys and gals… I’m late to the party as usual… a few failed attempts using HA in the past, recently decided to give it another shot after finding 66pg PDF online about this pi proxy setup for SunPower systems… took me a couple of days, got it up and running… oh, WOW, data…
a quick thanks to Dean, Scott, and anyone else that’s mentioned in the document I found… looks like you guys are all here too… found this today, after playing with my new data over the past couple of weeks…
I have a SunPower system, installed Oct 2018, PVS5X, (17) 360W panels, central CA SoCal Edison territory… I also have Sense, EAGLE-200, Flume (water meter) and planning on setting up SDR for gas meter…
so I setup HA originally on a pi3b, but NodeRed wouldn’t work right (taking hours to update)… so I installed docker on my home media server, installed HA there, and wow, much much faster (less than a minute compared to the pi) and stable than running on a pi… anyway, 194 SunPower entities later, I can’t believe the info I have now… when my system was first put online, my installer gave me a login to their system, being able to see each panel power and such, but this has even more… sunpower took my login away after about a year and wouldn’t give it back, so I’ve been very unhappy not knowing the true status of my system… but with this, I even have the panel temps… wow…
I got my energy dashboard setup, now I need to setup the grafana/influxdb stuff… and I’m getting my installer to send me a diagram of where my panel s/n numbers are installed in my array, the plan is create a dashboard with my panel layout and the individual data of each panel… much like the sunpower installer access… I also want to find a way to push my info to PVOutput… I’ve been doing it everyday by hand since Oct 2018… now its time to automate it… my 3rd goal here is to finish my panel auto-cleaning system… I’m going to setup and use 2in tall rainbird popup sprinklers around my array to keep it clean… I already have all the parts, just need the time to sit down and finish it… the rainbird controller is already added to my HA install…
let me know if there is anything I can help anyone with… again, glad to have finally found this…
