I have a central heating system from Honeywell called Evohome and I wanted to know when the wireless heating and hot water controllers turned my boiler on and off.
I guess this has been covered on here before but I’ll post what I’ve done in case it helps others.
The components I’ve used are as follows:
ESP8266: https://www.aliexpress.com/item/32529101036.html
Here is a pic of the two in action:
As you can see below, my heating system junction box looks like a spaghetti mess!
However, if you’re careful with the 240V, you can trace all the cables and work out what it does. Here is my wiring diagram that includes the optocoupler module (I created this in Google Drawing):
The ESP module is flashed with the Tasmota firmware: https://tasmota.github.io/docs/
Within Tasmota, set the module as Generic and set up a switch/relay pair. You need to use relays so that we can have multiple POWER entries in MQTT, and have the state retained for when HA restarts.
I set the following commands within the Tasmota console:
Set so that on/off messages are sent via MQTT
switchtopic 1
Sets switches to switchmode 2 (inverted follow mode (0 = ON, 1 = OFF))
switchmode1 2
switchmode2 2
switchmode3 2
Need to set a specific switch MQTT topic which is needed for enabling switchretain on
switchtopic optocoupler
Set so that HA can pick up the switch state after a reboot
switchretain on
The console will show the following when you toggle power on/off
19:32:29 MQT: cmnd/optocoupler/POWER1 = OFF (retained)
19:32:40 MQT: cmnd/optocoupler/POWER2 = ON (retained)
19:32:43 MQT: cmnd/optocoupler/POWER2 = OFF (retained)
My Tasmota home screen looks like this:
You need to set up and configure MQTT as well. In my case Tasmota sends MQTT messages to an MQTT broker that Home Assistant monitors via the sensors below.
Within Home Assistant, I use the following binary sensors:
binary_sensor:
- platform: mqtt
state_topic: "cmnd/optocoupler/POWER1"
payload_on: "ON"
payload_off: "OFF"
- platform: mqtt
state_topic: "cmnd/optocoupler/POWER2"
payload_on: "ON"
payload_off: "OFF"
- platform: mqtt
state_topic: "cmnd/optocoupler/POWER3"
payload_on: "ON"
payload_off: "OFF"
The wiring between the Optocoupler and ESP module is as follows:
VCC - 3V3
GND - GND
OUT1 - GPIO 12
OUT2 - GPIO 13
OUT3 - GPIO 14
Here is a close-up pic:
To create the short wires seen above, I used this crimping set:
I designed and 3D printed the box to house them in seeing as 240v is involved:
Here is the setup I used for testing:
Hopefully that’s covered everything, but I’ll edit and update if needs be.
