Is it possible to use OR in a trigger or something similar?
I want to use CHOOSE in my automation conditions the service call would depend on what triggered the automation.
For example
The below will turn on one person’s bedside lamp if their phone is placed on the charger first. I currently run two separate automations but wondered if I could consolidate them in one by OR in trigger then CHOOSE in conditions.
- alias: First to Bed
mode: single
- platform: state
entity_id: sensor.iphone_r_battery_state
to: Charging
- Not Charging
- Full
condition:
condition: and
conditions:
- condition: time
after: '20:00:00'
before: '03:00:00'
- condition: state
entity_id: input_boolean.holiday_mode
state: 'off'
- condition: template
value_template: '{{ is_state("sensor.iphone_m_battery_state", "Not Charging")
value_template: '{{ is_state("person.m", "home") }}'
- service: script.r_first_to_bed
- platform: state
to: Charging
- Not Charging
- Full
- platform: state
entity_id: sensor.iphone_m_battery_state
to: Charging
- Not Charging
- Full
Then in the choose you choose based on the trigger id, and do your checks (which you can do with state checking, not sure why you have used templates.
choose:
- conditions:
- condition: trigger
- condition: state
state: "Not Charging"
- condition: state
entity_id: person.m
state: home
sequence:
Hopefully that gives you enough information for you to see how you would then use option 2 in the choose to react to the other person getting into bed first.
As an aside - how does person m not being home have any bearing on whether or not person r is the first to bed?
I think (around 3 years ago so can’t be 100% certain now) originally I added that condition to run a third automation if that condition was not met. Confusing, I know, and that’s why I’m trying to tidy up all my older scripts and automations now.
