Getting really frustated here. How can I change the color of the orange slider in the standard thermostat card?
Just glancing at it, I think it might be dynamic depending on your thermostat mode.
I didn’t try to customize it, so I don’t know if it can be, although I’m guessing it can:
--round-slider-bar-color: var(--mode-color); # lower "colored" portion of the slider
--round-slider-path-color: var(--disabled-text-color); # upper "uncolored" portion of the slider
Unfortunatey that doesn’t work. Tried a lot of options and tried looking it up through Chrome’s development tools. Nothing seems to work…
That’s where I got the above from.
Did also you try redefining --heat-color to be something else?
Hi, did you find a way to change the thermostat cooling and heating card color please ? Tryed a lot of stuff but none worked…
As of right now, the issue is still open:
Hey guys.
Do you know of any way that we can tweak the color of the thermostat gauge when an A/C is turned on by a remote (such as a Broadlink IR blaster) and there is a power sensor (such as a smart energy plug) that detects this change in the state?
