darkorange:
primary-color: "#ff9800"
light-primary-color: "#ffc947"
dark-primary-color: "#c66900"
text-primary-color: "#ffffff"
primary-background-color: "#37464f"
sidebar-text_-_background: "#62717b"
card-background-color: "#263137"
paper-card-background-color: "#263137"
paper-card-header-color: "var(--text-primary-color)"
secondary-background-color: "var(--primary-background-color)"
primary-text-color: "var(--text-primary-color)"
secondary-text-color: "var(--primary-color)"
paper-listbox-background-color: "var(--sidebar-text_-_background)"
paper-toggle-button-checked-ink-color: "var(--dark-primary-color)"
paper-toggle-button-checked-button-color: "var(--dark-primary-color)"
paper-toggle-button-checked-bar-color: "var(--dark-primary-color)"
paper-slider-knob-color: "var(--primary-color)"
paper-slider-knob-start-color: "var(--primary-color)"
paper-slider-pin-color: "var(--primary-color)"
paper-slider-active-color: "var(--primary-color)"
paper-slider-secondary-color: "var(--light-primary-color)"
paper-slider-container-color: "var(--sidebar-text_-_background)"
paper-progress-secondary-color: "var(--sidebar-text_-_background)"
paper-item-selected_-_background-color: "var(--primary-color)"
paper-item-icon_-_color: "var(--text-primary-color)"
paper-item-icon-color: "var(--sidebar-text_-_background)"
paper-item-icon-active-color: "var(--primary-color)"
paper-grey-50: "var(--sidebar-text_-_background)"
paper-grey-200: "var(--primary-background-color)"
label-badge-background-color: "var(--sidebar-text_-_background)"
label-badge-text-color: "var(--text-primary-color)"
label-badge-red: "var(--primary-color)"
label-badge-blue: "var(--light-primary-color)"
label-badge-green: "var(--dark-primary-color)"
label-badge-yellow: "var(--text-primary-color)"
label-badge-grey: "var(--paper-grey-500)"
table-row-background-color: "var(--paper-card-background-color)"
table-row-alternative-background-color: "var(--sidebar-text_-_background)"
Awesome!
(only 49/9 mpbs up/download? Tss… )
Enough for me (and still waiting for fiber…)
Using @Bram_Kragten’s theme as a base, used a blue instead of orange:
darkblue:
primary-color: "#396FB6"
light-primary-color: "#77a0d4"
dark-primary-color: "#3539ce"
sidebar-text_-_background: "#3c4348"
Hi
I have copied your code into my configuration.yaml as follows:
frontend:
themes:
darkorange:
table-row-alternative-background-color: "var(--sidebar-text_-_background)”
but it doesnt seem to change to orange? do you know why?
Thanks.
I’m loving the darkorange theme. Would it be possible to fix the date picker in history and logbook?
Maybe you already solved your problem, but I had the same issue. In my case it it took a few minutes and restarts to get it up and running. beside this I had moved each theme to it’s own file, to keep things organized.
frontend:
themes:
darkblue: !include themes/dark_blue.yaml
I created a subfolder named ‘themes’ to contain all the themes neat and organized, for example the file 'dark_blue.yaml:
I noticed that the spaces before the code do not matter, as long as all the lines are aligned. But remember: do not include the name (‘darkblue’) again in the subfile (dark_blue.yaml), since it is already declared in the ‘fronted’ section.
Cheers!
I am using this awesome theme for a long time.
I noticed now that the settings -> devices window shows white text on a white background so not readable.
Can you fix this please?
Thanks in advance.
Regards, Eric
This the is added to Home Assistant Community Themes (with HACS support)
