@wietse1
Here’s the setup I use:
esphome:
platform: ESP8266
board: d1_mini
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "<USETHEONEHACAMEUPWITHONINSTALATION>"
ota:
password: "<HAWILLSUGGESTONEONINSTALATION>"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Mvcontroller Fallback Hotspot"
password: "<APASSWORDYOUDECIDE"
i2c:
output:
- platform: esp8266_pwm
pin: D6
frequency: 1000 Hz
inverted: true
type: float
write_action:
- logger.log: "Something was written to dummy."
switch:
- platform: gpio
name: "Orcon speed bypass"
pin:
number: D8
inverted: False
fan:
- name: "Orcon"
icon: "mdi:hvac"
platform: speed # sliding output
output: dummy
restore_mode: ALWAYS_ON
on_turn_on:
- logger.log: "Turning on Orcon"
on_turn_off:
- logger.log: "Turning off Orcon"
- lambda: "id(orcon).speed = 1;"
on_speed_set:
- logger.log: "Speed changed."
- lambda: |-
// Set a little margin so we don't keep toggling the relay if
// the requested and set speeds are very similar.
int margin = 5;
// Contains requested speed by the machine (0-100)
int req = int(id(orcon_mv_requested_speed).state);
// Contains requested speed by the user (0-100)
int now = int(id(orcon).speed);
// ESP_LOGD("req", "%d", req);
// ESP_LOGD("now", "%d", now);
if (now > (req - margin)) {
id(bypass).turn_on();
id(orcon_mv_pwm_out).set_level(
float(now / 100.0)
} else {
id(bypass).turn_off();
id(orcon_mv_pwm_out).set_level(0.0);
- platform: pulse_counter
pin: D5
name: Orcon Tachometer
update_interval: 5s
accuracy_decimals: 0
internal_filter: 250us
unit_of_measurement: rpm
- platform: duty_cycle
name: "Orcon MV Requested speed"
internal: true
unit_of_measurement: "%"
pin:
number: D7
mode: INPUT_PULLUP
inverted: no
update_interval: 20s
filters:
lambda: "return int(x);"
on_value:
- lambda: |-
// Hacky way to trigger the original code instead of duplicating.
if (id(orcon).state) {
auto call = id(orcon).turn_on();
call.set_speed(id(orcon).speed);
call.perform();
and for the automation to turn it on when the humidity rises in the bathroom:
alias: Bathroom - ventilation on
description: ""
- platform: numeric_state
entity_id:
- sensor.humidity_temp_1_humidity
for:
hours: 0
minutes: 1
seconds: 0
above: 72
condition: []
- service: fan.turn_on
metadata: {}
percentage: 100
entity_id: fan.orcon
mode: single
and off again on a certain level:
alias: Bathroom - ventilation back to auto
description: ""
entity_id:
for:
hours: 0
minutes: 1
seconds: 0
below: 65
condition: []
- service: fan.turn_off
data: {}
mode: single
