Order from a menu
Hey guys,
Im using home assistant in my sauna to control lights and music and such.
Now I also provide a range of snacks/meals in the sauna and I wonder if possible, what would be a good way to get customers choose from a menu in home assistant and that I receive a mail and/or message/notifications
or if not possible to add a menu, just like a blank box where they can type in anything and that I get the message on my phone/pc
thanks in advance
Do you already know the Shopping List integration?
I did not :slight_smile:
thanks for this. I will look into it and see how this helps me
I looked into it but not sure if this can do what I need/want.
I would need to make my own list where a customer can check what they want and press a send button and that I get a mail/message
With a few helpers and 2 scripts you can create a menu selection without installing an integration. Would have an output like this:
The code:
#### INPUT SELECT
input_select:
  menu_pizza:
    icon: mdi:pizza
    options:
      - 1
      - 2
      - 3
      - 4
    initial: …
  menu_french_fries:
    icon: mdi:french-fries
    options:
      - 1
      - 2
      - 3
      - 4
    initial: …
  menu_cucumber_salad:
    icon: mdi:sprout
    options:
      - 1
      - 2
      - 3
      - 4
    initial: …
#### INPUT TEXT
input_text:
  menu_freetext:
    icon: mdi:pencil-outline
    initial: ' '
#### GROUP
group:
  menu_selection:
    entities:
      - input_select.menu_pizza
      - input_select.menu_french_fries
      - input_select.menu_cucumber_salad
#### SCRIPT
script:
  menu_messaging:
    alias: Menu Messaging
    icon: mdi:cast-audio-variant
    sequence:
      - service: notify.YOUR_NOTIFY_SERVICE
          target: YOUR_NOTIFY_ENTITY
          title: Order {{ now().strftime('%F | %R') }}
          message: |
            {% for item in expand('group.menu_selection') -%}
              {% if states(item.entity_id) != '…' %}
                {{ states(item.entity_id) }} x {{ item.attributes.friendly_name }}
              {% endif %}
            {%- endfor -%}
            {% set text = states('input_text.menu_freetext') %}
            {{ 'Additional information: ' ~ text if text |length > 1 else 'none' }}
  menu_fields_clear:
    alias: Clear Menu Selection
    icon: mdi:trash-can-outline
    sequence:
      - service: input_select.select_option
          option: …
          entity_id:
      - service: input_text.set_value
          value: ''
          entity_id: input_text.menu_freetext
this is amazing. thanks you so much
