I use YAML mode for my lovelace configuration. ui-lovelace.yaml
contains:
title: Beatrice
views: !include_dir_merge_list ui-lovelace
The ui-lovelace/
folder contains a hierarchy of folders and files which assemble into a working interface. The top level of the hierarchy is:
$ ls -l ui-lovelace/
total 16
drwxr-xr-x 2 root root 4096 Apr 21 11:00 000-default
drwxr-xr-x 2 root root 4096 Apr 17 07:24 020-map
drwxr-xr-x 2 root root 4096 Apr 22 10:51 030-spaces
drwxr-xr-x 3 root root 4096 Apr 22 10:51 040-services
Each folder contains a dashboard definition which begins in a similar
way. For example, the 000-default
folder contains a 000-default.yaml
file which begins:
- title: Home
path: default_view
type: panel
cards:
I expect my menu to be ordered according to the !include alphabetic sort, but in fact my menu bar items are ordered “SPACES SERVICES MAP HOME”
Nothing I do in terms of renaming the included directories or their included yaml files results in a change in the established order, which seems to be stuck. I have checked the order in the .storage
direcory’s ui-lovelace
file and it is correct (in the sense that the view entries are ordered alphabetically).
So, how do I dictate the order in which dashboards appear in the lovelace menu bar?
PR
