Hello, I’m trying to upgrade to latest home assistant core version but Orjson can’t be installed.
I’m using linux alpine 3.12 and python 3.10.
This is the output message:
Collecting orjson
Using cached orjson-3.7.7.tar.gz (640 kB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... done
Building wheels for collected packages: orjson
Building wheel for orjson (pyproject.toml) ... error
error: subprocess-exited-with-error
× Building wheel for orjson (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [49 lines of output]
Running `maturin pep517 build-wheel -i /root/homeassistant3.10/bin/python3.10 --compatibility off`
warning: unused manifest key: package.resolver
warning: unused manifest key: package.rust-version
Compiling target-lexicon v0.12.4
Compiling autocfg v1.1.0
Compiling once_cell v1.13.0
Compiling serde v1.0.138
Compiling libc v0.2.126
Compiling cfg-if v1.0.0
Compiling version_check v0.9.4
Compiling encoding_rs v0.8.31
Compiling serde_json v1.0.82
Compiling ryu v1.0.10
Compiling itoa v1.0.2
Compiling simdutf8 v0.1.4
Compiling associative-cache v1.0.1
Compiling smallvec v1.9.0
Compiling inlinable_string v0.1.15
Compiling bytecount v0.6.3
error: could not compile `smallvec`.
To learn more, run the command again with --verbose.
warning: build failed, waiting for other jobs to finish...
error: build failed
💥 maturin failed
Caused by: Failed to build a native library through cargo
Caused by: Cargo build finished with "exit status: 101": `cargo rustc --manifest-path Cargo.toml --message-format json --release --lib -- -C link-arg=-s`
📦 Including license file "LICENSE-APACHE"
📦 Including license file "LICENSE-MIT"
🔗 Found pyo3-ffi bindings
🐍 Found CPython 3.10 at /root/homeassistant3.10/bin/python3.10
error[E0658]: unions with non-`Copy` fields are unstable
--> /root/.cargo/registry/src/github.com-1ecc6299db9ec823/smallvec-1.9.0/src/lib.rs:409:1
409 | / union SmallVecData<A: Array> {
410 | | inline: core::mem::ManuallyDrop<MaybeUninit<A>>,
411 | | heap: (*mut A::Item, usize),
412 | | }
| |_^
= note: see issue #55149 <https://github.com/rust-lang/rust/issues/55149> for more information
error: aborting due to previous error
For more information about this error, try `rustc --explain E0658`.
Error: command ['maturin', 'pep517', 'build-wheel', '-i', '/root/homeassistant3.10/bin/python3.10', '--compatibility', 'off'] returned non-zero exit status 1
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for orjson
Failed to build orjson
ERROR: Could not build wheels for orjson, which is required to install pyproject.toml-based projects
Any help would be appreciated. Thanks
