Orphan Entity Cleaner Integration
Many New Features!
Exclude default platforms
Compare scan
Dry run
Orphan Entity Cleaner — Custom Integration for Home Assistant
HACS Custom
HA Version
A custom integration that finds and deletes orphan entities — entities left in the registry after the integration that created them has been removed or failed — via a web panel in the sidebar and services callable from scripts and automations.
Installation
Via HACS (recommended)
  1. In HACS → Integrations → ⋮ → Custom repositories
  2. Add the URL of this repository, category Integration
  3. Search for Orphan Entity Cleaner and install
  4. Restart Home Assistant
  5. Settings → Devices & Services → Add Integration → Orphan Entity Cleaner
Manual installation
  1. Copy the custom_components/orphan_cleaner/ folder to <config>/custom_components/
  2. Restart Home Assistant
  3. Settings → Devices & Services → Add Integration → Orphan Entity Cleaner
Web Panel
After installation, the Orphan Cleaner icon appears in the HA sidebar. All settings are controlled directly from the panel — no configuration flow needed after the initial setup.
Controls
Control Description
Scan Scans the registry and populates the table
Heuristic Enables detection method 4 (see below)
Min age (h) Minimum age in hours for an entity to be flagged
Ignore Add platforms or globs to exclude from the current session
Default ignore list Persistent ignore list, pre-loaded on every scan (see below)
Dry run Simulate deletion without removing anything (see below)
Filter Filter visible results by entity_id or platform
Select all / Deselect Bulk checkbox controls
Delete selected Delete selected entities with a confirmation dialog
Save & Delete Save a JSON backup of selected entities to /config/ before deleting
Ignore (session)
Type a platform name or glob pattern in the Ignore field in the control bar and press Enter or + Add. Ignored entities remain visible in the table but are greyed out and non-interactive. The orphan counter reflects the exclusion. This list is temporary and resets on page reload.
Default ignore list (persistent)
A collapsible section below the control bar. Entries here are saved to the integration’s config entry options and automatically loaded on every scan and page load. Supports:
  • Platform namestuya, shelly, imou_life
  • Platform globsimou_*, tuya_*
  • Entity ID globssensor.old_*, *_deprecated, sensor.*_temp
Press :floppy_disk: Save to persist the current list. Use the ? link for a full syntax reference.
Save & Delete
Save & Delete exports a timestamped JSON backup of the selected entities to /config/orphan_cleaner_backup_<timestamp>.json before proceeding with deletion. If the backup fails, deletion is aborted. The backup contains entity metadata (entity_id, platform, detection method, age, disabled state) and can be used as a reference in case of accidental deletion.
Dry run
Enable the Dry run checkbox in the toolbar before deleting. When active:
  • An amber warning banner appears to remind you that no changes will be made
  • Delete selected becomes Simulate
  • Save & Delete is hidden
  • Clicking Simulate highlights the selected entities with a would delete badge for 6 seconds and logs the result — nothing is actually removed
Dry run is also available as a parameter in the orphan_cleaner.delete_orphans service (see Services section).
Scan comparison
After the first scan, every subsequent scan shows a diff banner above the table:
vs previous scan: 3 new :up_arrow: · 1 gone :down_arrow: · 108 unchanged
Entities that are new since the last scan are highlighted with a yellow new badge. The banner is hidden when results are identical to the previous scan.
Detection Methods
Method 1 — orphaned_timestamp (reliable)
Home Assistant sets this field in the registry when, after a full restart, an entity is not claimed by any integration. This is the official signal and is always active.
Min age (h) filters out recently orphaned entities, useful if an integration is temporarily offline. Ages above 24 hours are displayed in days (e.g. 377d) in the panel table.
Method 2 — Dead config entry
If an entity’s config_entry_id points to a config entry that no longer exists or is in a FAILED / NOT_LOADED state, the entity is considered an orphan.
Method 3 — Unavailable state
Entities in unavailable state for longer than Min age (h) are flagged. Catches entities that HA marks with the yellow warning “no longer provided by the integration”.
Method 4 — Heuristic (optional)
Enabled by the Heuristic checkbox. Also flags entities with no config_entry_id and a platform not in the following exclusion list:
automation, counter, group, input_boolean, input_button, input_datetime, input_number, input_select, input_text, person, persistent_notification, scene, schedule, script, tag, template, timer, zone
Services
orphan_cleaner.scan
Runs the scan and fires the orphan_cleaner_orphans_found event on the HA event bus.
action: orphan_cleaner.scan
Event payload:
count: 5
orphans:
  - entity_id: sensor.old_shelly
    platform: shelly
    method: timestamp
    age_hours: 72.3
    disabled_by: null
Example automation:
automation:
    platform: event
    event_type: orphan_cleaner_orphans_found
  condition:
    condition: template
    value_template: "{{ trigger.event.data.count > 0 }}"
    service: notify.mobile_app
      title: "Orphan entities detected"
      message: "Found {{ trigger.event.data.count }} orphan entities."
Deletes the specified entities, or all detected orphans if none are specified.
Field Type Required Description
entity_ids list No Entities to delete. If omitted → all orphans
dry_run bool No Log only, without making changes (default: false)
# Delete all orphans
action: orphan_cleaner.delete_orphans
# Dry run
  dry_run: true
# Delete specific entities
  entity_ids:
    - sensor.old_device
    - binary_sensor.ghost_sensor
File Structure
├── __init__.py           ← setup, panel registration, teardown
├── config_flow.py        ← initial config flow
├── const.py              ← constants
├── manifest.json         ← integration metadata
├── orphan_detector.py    ← detection and deletion logic
├── panel_api.py          ← HTTP views (panel, scan, delete, export, ignore list)
├── services.py           ← HA services (scan, delete_orphans)
├── services.yaml         ← service documentation for Developer Tools
├── strings.json          ← UI labels
├── translations/
│   └── en.json
└── frontend/
    ├── panel.html        ← full web interface
    └── orphan-cleaner-panel.js
Recovering from accidental deletion
If you used Save & Delete, a backup file was written to /config/orphan_cleaner_backup_<timestamp>.json before the deletion. This file contains the metadata of all deleted entities.
What the backup contains
  "exported_at": "2024-11-15T10:32:00",
  "entity_count": 3,
  "entities": [
      "entity_id": "sensor.old_device_temperature",
      "platform": "tuya",
      "method": "dead_entry",
      "age_hours": 312.5,
      "disabled_by": null
What you can do
  • Check if the entity was truly orphaned — look at the method and age_hours fields. If age_hours is low, the integration may have been temporarily offline and the entity could reappear after a restart.
  • Reinstall the integration — if the platform (e.g. tuya, shelly, zha) is still active and the physical device is reachable, removing and re-adding the integration will recreate its entities automatically.
  • Restore custom attributes manually — if the entity reappears, you can reassign its area, icon, and aliases from the HA UI. The backup gives you the original entity_id to match it.
  • Clean up the recorder — if the entity had historical data and you want to remove it, use the recorder.purge_entities service with the entity_id from the backup.
What cannot be recovered
  • The entity registry entry itself — HA does not expose an API to re-insert entries manually.
  • Historical recorder data is not deleted by this integration, but it will no longer be linked to an active entity.
  • If the underlying integration or device no longer exists, the entity cannot be recreated without it.
Warnings
  • Always make a backup before deleting entities in bulk. Use Save & Delete to automatically export a JSON record before each deletion.
  • Deleted entities are removed from the registry: historical data in the recorder remains but is no longer associated with an active entity. To clean the recorder as well, use the recorder.purge_entities service.
  • An entity with orphaned_timestamp may belong to an integration that is temporarily offline. Increase Min age (h) if you have unstable integrations.
  • Deletion is irreversible. Entities cannot be restored from the backup — the backup is a reference record only.
License
MIT
Thanks for posting this. I tried using Spook and it didn't work for me. Yours worked great and easy to use!
Thank you! Spook is useful to find lost entities in YAML files.
Please star my project and share it!
