Hi folks. I have 2 zigbee networks attached to HA – one in my detached office using ZHA and another in the main house using z2m. I had added a Tradfri shortcut button to my z2m instance and it detected a OTA update which showed up in HA. Before updating, I decided I wanted to use the button in my office so I removed for z2m and added it via ZHA. Button added fine and I updated the firmware via ZHA. However the MQTT notification is still there in HA and I can’t get rid of it. I tried restarting both my z2m instance and HA but it’s still there. Any way to get rid of this?
Did you try the ‘ignore’ button ?
Sorry…should have said that pressing the Skip or Install button does nothing.
This shows up in the log if I try and press Install or Skip:
Logger: homeassistant.helpers.service
Source: helpers/service.py:246
First occurred: January 22, 2024 at 5:25:13 PM (25 occurrences)
Last logged: 8:18:20 AM
Referenced entities update.tradfri_shortcut_button_house are missing or not currently available
I’m wondering maybe if I add it back to z2m, I’ll be able to ignore? Was hoping to avoid that though.
