Bertus1
(bertus bots)
June 24, 2024, 10:24am
1
I put a Home Assistent image on an SD card using the Raspberry Pi Imager :
for RPi-5 with HomeAssistent OS 12.4 released 2024-06-18 on 32GB SD card
after power-up of the RPi-5 with this image it hangs on Trying partition 0…
see power-up screen shot.
How to resolve this???
Baxxy13
(Baxxy13)
June 24, 2024, 11:08am
2
Flash 12.3 and then Update from ui to 12.4
Or wait till the issue ist identified and fixed.
opened 03:58PM - 20 Jun 24 UTC
bug
board/raspberrypi
### Describe the issue you are experiencing
The SD card was flashed with the Ra… spberryPi Imager 1.8.5 and for test purposes with BalenaEtcher.
I used the following image with BalenaEtcher:
https://github.com/home-assistant/operating-system/releases/download/12.4/haos_rpi5-64-12.4.img.xz
Unfortunately the Pi5 is stuck in the boot menu. No matter if with the RaspberryPi Imager or with BalenaEtcher.
![IMG_0072](https://github.com/home-assistant/operating-system/assets/162861987/c7b064a6-9d3e-4aba-91ee-9bdc8369572a)
Finally I downloaded haos_rpi5-64-11.5.img and flashed it. This works perfectly on the Pi5.
### What operating system image do you use?
rpi5-64 (Raspberry Pi 5 64-bit OS)
### What version of Home Assistant Operating System is installed?
12.4
### Did the problem occur after upgrading the Operating System?
Yes
### Hardware details
Raspberry Pi 5 with 8GB Ram
### Steps to reproduce the issue
1.Flash HAOS 12.4 on SD-Card
2.Boot the Pi5 with the SD-Card
3.
### Anything in the Supervisor logs that might be useful for us?
```txt
### Anything in the Host logs that might be useful for us?
```txt
### System information
_No response_
### Additional information
_No response_
