Os-agent installation for
Running HA supervised but unable to install OS-Agent daemon under Raspian on RPI4 using command line for latest update. Downloaded the following
os-agent_1.4.1_linux_armv7.deb
then used the command
sudo dpkg -i os-agent_1.4.1_linux_armv7.deb
which failed and returned message
error: ‘os-agent_1.4.1_linux_armv7.deb’ is not a debian format archive.
command uname -a returns armv71
Can anyone help?
Maybe the package was broken during the download.
  1. Open https://github.com/home-assistant/os-agent/releases/download/1.4.1/checksums.txt and look for the checksum for os-agent_1.4.1_linux_armv7.deb.
  2. Now open a shell (CLI) and go to the directory where you have downloaded os-agent_1.4.1_linux_armv7.deb to before.
  3. Enter the following shell command:
    sudo sha512sum os-agent_1.4.1_linux_armv7.deb
Does the output of above’s command from step 3 match with the checksum within the checksums.txt file from step 1?
If the checksums do not match, delete os-agent_1.4.1_linux_armv7.deb and redownload the file. Make sure the checksum matches before trying to install.
