OS for Nextbook
I have this very old Nextbook tablet given to me by my cousin. The original OS installed was Windows 8. There was a issue with the batteries so I somehow got the battery replaced. I had to reinstall Windows 8 but as I didn’t have the product key windows could not be activated.
It has an Atom processor. Can I install Home assistant OS on it or any other OS so that I can use it as a screen for Homeassistant.
If you want to use it as a screen for controlling HA, installing HAOS will not help you. Try searching for kiosk mode on the forums and you’ll likely find some info on this.
For W10/11 you don’t need a key anymore (but the free version will have a few restrictions).
But why not go for a linux distribution? They are all for free :thinking:
Ofc you van also install HAOS, but the machine has to be able to boot from UEFI (check bios)
But…HAOS will only give you HA, nothing else…
I will install Linux mint and check it out. Hopefully browser should work as a touchscreen tablet
I loaded Linux mint. The installation went fine without errors. But it was not booting. Something went wrong with Grub installation.
Is there any other OS supporting touchscreen or where I just get the browser working for homeassistant dashboard.
Twice I tried installing Linux Mint.
