Hi Pete, the log full file is 30mb! Is there a specific bit I can extract that would be helpful?
It seems to be both local and cloud, which leads me to suspect it’s the HA Yellow’s connectivity rather than anything else. I’ll power cycle it and see what it comes back up with.
Here’s the log since power cycling the Yellow:
2022-12-30 12:38:17.111 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration nibe which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:17.115 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration powercalc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:17.117 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:17.120 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration solcast_solar which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:17.123 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration apple_airplayer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:17.126 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration feedparser which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:17.129 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration comfoconnect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:17.132 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration fullykiosk which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:17.134 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration aarlo which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:17.137 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration adaptive_lighting which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:17.139 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration shelly which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:17.142 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration meross_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-12-30 12:38:32.451 ERROR (MainThread) [snitun.client.client_peer] Challenge/Response error with SniTun server (0 bytes read on a total of 32 expected bytes)
2022-12-30 12:38:32.460 ERROR (MainThread) [hass_nabucasa.remote] Connection problem to snitun server
2022-12-30 12:39:21.525 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: hassio
2022-12-30 12:39:49.630 WARNING (ArloBackgroundWorker) [pyaarlo] request-error=ReadTimeout
2022-12-30 12:40:08.672 WARNING (MainThread) [homeassistant.helpers.frame] Detected integration that uses deprecated `async_get_registry` to access entity registry, use async_get instead. Please report issue to the custom integration author for shelly using this method at custom_components/shelly/__init__.py, line 356: await self.hass.helpers.entity_registry.async_get_registry()
2022-12-30 12:40:22.054 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform webostv is taking over 10 seconds.
2022-12-30 12:40:22.055 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform webostv is taking over 10 seconds.
2022-12-30 12:40:22.107 ERROR (MainThread) [pyatv.protocols.airplay] Failed to set up remote control channel
File "/usr/local/lib/python3.10/site-packages/pyatv/support/http.py", line 390, in send_and_receive
await event.wait()
File "/usr/local/lib/python3.10/asyncio/locks.py", line 214, in wait
await fut
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.10/site-packages/pyatv/support/http.py", line 389, in send_and_receive
async with async_timeout.timeout(4):
File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 129, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.10/site-packages/async_timeout/__init__.py", line 212, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/airplay/__init__.py", line 258, in _connect_rc
await control.start(str(core.config.address), control_port, credentials)
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/airplay/remote_control.py", line 56, in start
self.verifier = await verify_connection(credentials, self.connection)
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/airplay/auth/__init__.py", line 103, in verify_connection
has_encryption_keys = await verifier.verify_credentials()
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/airplay/auth/hap_transient.py", line 66, in verify_credentials
await self.http.post(
File "/usr/local/lib/python3.10/site-packages/pyatv/support/http.py", line 360, in post
return await self.send_and_receive(
File "/usr/local/lib/python3.10/site-packages/pyatv/support/http.py", line 393, in send_and_receive
raise TimeoutError(f"no response to {method} {uri} ({protocol})") from ex
TimeoutError: no response to POST /pair-setup (HTTP/1.1)
2022-12-30 12:40:22.166 ERROR (MainThread) [pyatv.protocols.airplay] Failed to set up remote control channel
await event.wait()
await fut
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/airplay/auth/hap_transient.py", line 50, in verify_credentials
resp = await self.http.post(
2022-12-30 12:40:22.247 ERROR (MainThread) [homeassistant.components.tado.device_tracker] Cannot load Tado data
2022-12-30 12:40:22.309 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform forecast_solar is taking over 10 seconds.
2022-12-30 12:40:22.417 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform speedtestdotnet is taking over 10 seconds.
2022-12-30 12:40:23.017 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Hue Bridge' for hue integration not ready yet: Error connecting to the Hue bridge at 192.168.9.117; Retrying in background
2022-12-30 12:40:23.052 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform legacy tado
2022-12-30 12:40:25.735 ERROR (MainThread) [homeassistant.util.logging] Exception in async_discover when dispatching 'mqtt_discovery_new_sensor_mqtt': ({'name': 'Battery Status', 'state_topic': 'solis2mqtt/battery_status', 'unique_id': 'solis2mqtt/battery_status', 'device_class': None, 'state_class': 'measurement', 'unit_of_measurement': None, 'device': {'name': 'solis2mqtt', 'model': 'solis2mqtt', 'manufacturer': 'Ginlong Technologies', 'identifiers': 'solis2mqtt', 'sw_version': 'solis2mqtt 0.7'}, 'platform': 'mqtt'},)
File "/usr/src/homeassistant/homeassistant/components/mqtt/mixins.py", line 328, in async_discover
config: DiscoveryInfoType = discovery_schema(discovery_payload)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 232, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 355, in _exec
raise e if self.msg is None else AllInvalid(self.msg, path=path)
File "/usr/local/lib/python3.10/site-packages/voluptuous/validators.py", line 351, in _exec
v = func(v)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 272, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 818, in validate_callable
return schema(data)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 595, in validate_dict
return base_validate(path, iteritems(data), out)
File "/usr/local/lib/python3.10/site-packages/voluptuous/schema_builder.py", line 433, in validate_mapping
raise er.MultipleInvalid(errors)
voluptuous.error.MultipleInvalid: expected SensorDeviceClass or one of 'date', 'duration', 'timestamp', 'apparent_power', 'aqi', 'battery', 'carbon_monoxide', 'carbon_dioxide', 'current', 'distance', 'energy', 'frequency', 'gas', 'humidity', 'illuminance', 'moisture', 'monetary', 'nitrogen_dioxide', 'nitrogen_monoxide', 'nitrous_oxide', 'ozone', 'pm1', 'pm10', 'pm25', 'power_factor', 'power', 'precipitation', 'precipitation_intensity', 'pressure', 'reactive_power', 'signal_strength', 'speed', 'sulphur_dioxide', 'temperature', 'volatile_organic_compounds', 'voltage', 'volume', 'water', 'weight', 'wind_speed' for dictionary value @ data['device_class']
2022-12-30 12:40:25.744 ERROR (MainThread) [homeassistant.util.logging] Exception in async_discover when dispatching 'mqtt_discovery_new_sensor_mqtt': ({'name': 'Storage Mode', 'state_topic': 'solis2mqtt/storage_mode', 'unique_id': 'solis2mqtt/storage_mode', 'device_class': None, 'state_class': None, 'unit_of_measurement': None, 'device': {'name': 'solis2mqtt', 'model': 'solis2mqtt', 'manufacturer': 'Ginlong Technologies', 'identifiers': 'solis2mqtt', 'sw_version': 'solis2mqtt 0.7'}, 'platform': 'mqtt'},)
v = func(v)
return schema(data)
2022-12-30 12:40:25.752 ERROR (MainThread) [homeassistant.util.logging] Exception in async_discover when dispatching 'mqtt_discovery_new_sensor_mqtt': ({'name': 'Inverter Status', 'state_topic': 'solis2mqtt/inverter_status', 'unique_id': 'solis2mqtt/inverter_status', 'device_class': None, 'state_class': None, 'unit_of_measurement': None, 'device': {'name': 'solis2mqtt', 'model': 'solis2mqtt', 'manufacturer': 'Ginlong Technologies', 'identifiers': 'solis2mqtt', 'sw_version': 'solis2mqtt 0.7'}, 'platform': 'mqtt'},)
v = func(v)
return schema(data)
2022-12-30 12:40:25.759 ERROR (MainThread) [homeassistant.util.logging] Exception in async_discover when dispatching 'mqtt_discovery_new_sensor_mqtt': ({'name': 'Battery Two Voltage', 'state_topic': 'solis2mqtt/batt2_voltage', 'unique_id': 'solis2mqtt/batt2_voltage', 'device_class': None, 'state_class': None, 'unit_of_measurement': 'V', 'device': {'name': 'solis2mqtt', 'model': 'solis2mqtt', 'manufacturer': 'Ginlong Technologies', 'identifiers': 'solis2mqtt', 'sw_version': 'solis2mqtt 0.7'}, 'platform': 'mqtt'},)
v = func(v)
return schema(data)
2022-12-30 12:40:26.051 ERROR (MainThread) [homeassistant] Error doing job: Exception in callback MQTT._mqtt_handle_message(<paho.mqtt.cl... 0x7f7911c430>)
File "/usr/local/lib/python3.10/asyncio/events.py", line 80, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/components/mqtt/client.py", line 695, in _mqtt_handle_message
self._mqtt_data.state_write_requests.process_write_state_requests()
File "/usr/src/homeassistant/homeassistant/components/mqtt/models.py", line 264, in process_write_state_requests
entity.async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 545, in async_write_ha_state
self._async_write_ha_state()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 583, in _async_write_ha_state
state = self._stringify_state(available)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 551, in _stringify_state
if (state := self.state) is None:
File "/usr/src/homeassistant/homeassistant/components/sensor/__init__.py", line 690, in state
raise ValueError(
ValueError: Invalid datetime: sensor.system_datetime provides state '2022-12-30 11:42:04', which is missing timezone information
2022-12-30 12:40:26.079 ERROR (MainThread) [homeassistant.components.sensor] Error adding entities for domain sensor with platform mqtt
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 428, in async_add_entities
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 692, in _async_add_entity
await entity.add_to_platform_finish()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 789, in add_to_platform_finish
self.async_write_ha_state()
raise ValueError(
2022-12-30 12:40:28.301 ERROR (MainThread) [homeassistant.components.apple_tv] Failed to connect
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/mrp/protocol.py", line 274, in _receive
await semaphore.acquire()
File "/usr/local/lib/python3.10/asyncio/locks.py", line 390, in acquire
await fut
File "/usr/src/homeassistant/homeassistant/components/apple_tv/__init__.py", line 222, in connect_once
await self._connect(conf, raise_missing_credentials)
File "/usr/src/homeassistant/homeassistant/components/apple_tv/__init__.py", line 323, in _connect
self.atv = await connect(conf, self.hass.loop, session=session)
File "/usr/local/lib/python3.10/site-packages/pyatv/__init__.py", line 135, in connect
await atv.connect()
File "/usr/local/lib/python3.10/site-packages/pyatv/core/facade.py", line 575, in connect
if await setup_data.connect():
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/mrp/__init__.py", line 941, in _connect
await protocol.start()
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/mrp/protocol.py", line 142, in start
self.device_info = await self.send_and_receive(
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/mrp/protocol.py", line 261, in send_and_receive
return await self._receive(identifier, timeout)
File "/usr/local/lib/python3.10/site-packages/pyatv/protocols/mrp/protocol.py", line 273, in _receive
async with async_timeout.timeout(timeout):
2022-12-30 12:40:28.311 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Bedroom' for apple_tv integration not ready yet: Not found at 192.168.9.32, waiting for discovery; Retrying in background
2022-12-30 12:40:28.318 ERROR (MainThread) [homeassistant.components.apple_tv] Failed to connect
await fut
await atv.connect()
2022-12-30 12:40:28.323 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Kitchen' for apple_tv integration not ready yet: Not found at 192.168.9.38, waiting for discovery; Retrying in background
2022-12-30 12:40:36.665 ERROR (Update loop) [pyShelly] Timeout connecting to http://192.168.9.6/shelly [shellyplus1pm-a8032ab9d2e0.localdomain]
2022-12-30 12:40:37.366 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: climate.nibe, switch.nibe, sensor.nibe, water_heater.nibe, fan.nibe
2022-12-30 12:40:42.991 WARNING (MainThread) [homeassistant.components.climate] Setup of climate platform nibe is taking over 10 seconds.
2022-12-30 12:40:42.994 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform nibe is taking over 10 seconds.
2022-12-30 12:40:43.000 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform nibe is taking over 10 seconds.
2022-12-30 12:40:43.006 WARNING (MainThread) [homeassistant.components.water_heater] Setup of water_heater platform nibe is taking over 10 seconds.
2022-12-30 12:40:43.008 WARNING (MainThread) [homeassistant.components.fan] Setup of fan platform nibe is taking over 10 seconds.
2022-12-30 12:41:15.293 WARNING (SyncWorker_9) [homeassistant.components.waze_travel_time.sensor] Error on retrieving data: empty response
2022-12-30 12:41:21.191 ERROR (MainThread) [homeassistant.components.apple_tv] Failed to connect
File "/usr/src/homeassistant/homeassistant/components/apple_tv/__init__.py", line 311, in _connect
raise ConfigEntryNotReady(
homeassistant.exceptions.ConfigEntryNotReady: Protocol(s) RAOP not yet found for Bedroom, waiting for discovery.
2022-12-30 12:41:24.799 ERROR (SyncWorker_0) [homeassistant] Error doing job: Unclosed client session
Thanks!
