OSError: inotify watch limit reached
I’m using home assistant docker version 2021.1.5 on raspbian buster. My logs show the following error:
home-assistant   | Traceback (most recent call last):
home-assistant   |   File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
home-assistant   |     result = self.fn(*self.args, **self.kwargs)
home-assistant   |   File "/usr/src/homeassistant/homeassistant/components/folder_watcher/__init__.py", line 112, in startup
home-assistant   |     self._observer.start()
home-assistant   |   File "/usr/local/lib/python3.8/site-packages/watchdog/observers/api.py", line 255, in start
home-assistant   |     emitter.start()
home-assistant   |   File "/usr/local/lib/python3.8/site-packages/watchdog/utils/__init__.py", line 111, in start
home-assistant   |     self.on_thread_start()
home-assistant   |   File "/usr/local/lib/python3.8/site-packages/watchdog/observers/inotify.py", line 121, in on_thread_start
home-assistant   |     self._inotify = InotifyBuffer(path, self.watch.is_recursive)
home-assistant   |   File "/usr/local/lib/python3.8/site-packages/watchdog/observers/inotify_buffer.py", line 35, in __init__
home-assistant   |     self._inotify = Inotify(path, recursive)
home-assistant   |   File "/usr/local/lib/python3.8/site-packages/watchdog/observers/inotify_c.py", line 187, in __init__
home-assistant   |     self._add_dir_watch(path, recursive, event_mask)
home-assistant   |   File "/usr/local/lib/python3.8/site-packages/watchdog/observers/inotify_c.py", line 371, in _add_dir_watch
home-assistant   |     self._add_watch(full_path, mask)
home-assistant   |   File "/usr/local/lib/python3.8/site-packages/watchdog/observers/inotify_c.py", line 385, in _add_watch
home-assistant   |     Inotify._raise_error()
home-assistant   |   File "/usr/local/lib/python3.8/site-packages/watchdog/observers/inotify_c.py", line 402, in _raise_error
home-assistant   |     raise OSError("inotify watch limit reached")
home-assistant   | OSError: inotify watch limit reached
Anybody knows how to fix this?
