When trying to update the core and OS i get the following error in the log:
Logger: homeassistant.components.websocket_api.http.connection
Källa: components/websocket_api/commands.py:239
integration: Home Assistant WebSocket API (dokumentation, ärenden)
Inträffade först: 21:02:46 (1 händelser)
Senast loggade: 21:02:46
[139831346721600] Unexpected exception
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 213, in async_install
await async_update_os(self.hass, version)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 59, in _wrapper
data = await funct(*argv, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 226, in async_update_os
return await hassio.send_command(
File "/usr/src/homeassistant/homeassistant/components/hassio/handler.py", line 593, in send_command
raise HassioAPIError(error.get(ATTR_MESSAGE))
homeassistant.components.hassio.handler.HassioAPIError: 'OSManager.update' blocked from execution, system is not running - startup
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 239, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2738, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2779, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 975, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1047, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 157, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 461, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 215, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Operating System: 'OSManager.update' blocked from execution, system is not running - startup
