OSRAM bulb without switch in HA
Hi everyone. I have a problem with an OSRAM Zigbee bulb. Following a blackout, the light bulb maintained communication with Z2MQTT but the entity in HA is not available. I did some testing including eliminating the single OSRAM switch entity (on/off) in HA and then from the Z2MQTT interface. Now I managed to re-establish the connection (and I see OSRAM also in HA) but the switch entity to turn on/off (which I had deleted) no longer exists in HA despite having done a reset of the light bulb. In Home Assistant, I can only manage the effects, since that was another entity I hadn’t deleted. I also tried to delete it and reconfigure it from Z2MQTT but in any case there is no switch in HA. Advice? A thousand thanks!
The only entity exposed, there is no switch even among the disabled ones
