I have Osram lightify smart bulb - this model.
The bulb is connected directly to HA using ZigBee (the new ZHA introduced lately).
The problem is that HA assumes this is an RGB bulb while it’s actually white LED with variable temperature (2700K - 6000K) and shows the color select UI instead of the temperature select UI.
