Greetings,
I’ve integrated this light strip into my Home Assistant instance and I’m able to switch it on or to change colors.
Now I tried to come up with an Automation, to slowly turn on the light, meaning from zero to a warm white.
Problem: The light seems to remember the last state and starts from there. So in case the last state was a bright green, the Automation starts from there and slowly transforms into the target state.
I have seen that there is something concerning a memory and to reset this, the following line needs to be added:
"remember_state": true, // true, false (boolean)
But where do I set this? I’ve tried to set this as parameter in the Automation, but then the Automation does not start at all:
service: light.turn_on
remember_state: false
transition: 10
brightness: 130
rgb_color:
- 255
- 255
- 255
entity_id: light.osram_light_strip_light
Any idea on how to proceed?
Thanks a lot,
Fridolin
