Osram ZigBee Bulb Factory Reset
GitHub Gist link: https://gist.github.com/russellhq/5720c0d041290da83478f0c737d4db0e
Description
Use this Blueprint to factory reset your Osram Zigbee bulbs when you have them connected to a smart switch. This can be helpful if you are having trouble resetting your bulbs, are troubleshooting and need to reset a number of times or are swapping/resetting your hub and need to repair your bulbs.
Blueprint YAML Code
blueprint:
  name: Osram Zigbee Bulb Factory Reset
  description: Factory resets Osram Zigbee bulbs for re-pairing with a ZigBee Hub
  domain: automation
  input:
    input_boolean:
      description: This Input boolean will trigger the factory reset automation
      selector:
        entity:
          domain: input_boolean
    light_switch:
      description: The light switch to use for factory resetting the Osram bulb
      selector:
        entity:
          domain: switch
  - entity_id: !input input_boolean
    platform: state
    to: 'on'
  - service: switch.turn_on
    entity_id: !input light_switch
  - delay: '2'
  - repeat:
      count: '5'
      sequence:
        - service: switch.turn_off
        - delay: '5'
        - delay: '5'
  - service: input_boolean.turn_off
Dont have Osram light bulbs (yet) but appreciate the share :smiley: Clever! :slight_smile:
I would have never guessed that can be done without killing the power and cycling the physical switch… awesome idea and I learned something new.
Clever. I would have used the daylights out of something like this troubleshooting those glitchy GE Link zigbee bulbs back in the day.
