it would appear that ciso8601 is failing on compile, “unsupported architecture” and “architecture not supported” all over the place on typedef’s . Any flags to work around this, or will there have to be a different module used with home assistant to support Darwin?
Use the following export before running any commands.
export CFLAGS="-D__x86_64__
or prefix the command
CFLAGS="-D__x86_64__" python3 -m pip install homeassistant
