I’m getting “Invalid Config” for zwave with the following configuration:
zwave:
usb_path: /dev/cu.usb.modem1411
AFAIK the syntax is correct (2-space indent) and that is definitely the right path to the device (from the home directory).
zwave:
does the user running HA have R/W access to the zwave stick?
Yes. The stick’s info:
crw-rw-rw- 1 root wheel 20, 1 Nov 6 20:39 /dev/cu.usbmodem1411
Heh well I see one problem, your config says /dev/cu.usb.modem1411
but your ls
command says /dev/cu.usbmodem1411
