Can someone suggest why I have a device which doesn’t always show as having an IP on the Controller? In fact sometimes it doesn’t even appear in the list of clients at all even though it is on line.
I know it is on-line, not just because I am using, it but also the device is a Proxmox Server which is hosting the UniFi Controller itself.
As you can see, the uptime is being reported as less than thw UniFi Controller which can’t be true!
The UniFi Controller runs in a container on Proxmox which currently has just one other VM server which always appears as it should, it is just the Proxmox server that behaves strangely. Both servers are DHCP at the USG but have a static IP set in the client.
Any hints gratefully accepted.
