Error: RROR Error receiving acknowledge chunk OK: timed out
it happend when I do OTA update esphome version 1.9.0 to 1.9.1
Could you please support?
YAML:
substitutions:
friendly_name: 4-D1.Mini.TC-Mac.2C43-IP.31.56
ssid: "D1Minitc-Mac-2C43-Ip-31-56"
static_ip : 192.168.31.56
board: d1_mini
presence_output_pin: GPIO4 #D2
esphome:
friendly_name: ${friendly_name}
esp8266:
board: ${board}
framework:
platform_version : espressif8266
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: !secret api_encryption_key
ota:
- platform: esphome
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: ${static_ip}
gateway: 192.168.31.1
subnet: 255.255.255.0
ap:
ssid: ${ssid}
password: !secret ap_password
captive_portal:
web_server:
port: 80
uart:
tx_pin: TX
rx_pin: RX
baud_rate: 256000
parity: NONE
stop_bits: 1
ld2410:
switch:
- platform: ld2410
engineering_mode:
bluetooth:
name: "control bluetooth"
binary_sensor:
# Chân tín hiệu cảm biến riêng
- platform: gpio
pin: ${presence_output_pin}
name: "Out Pin Presence Sensor"
device_class: motion
# binary_sensor:
- platform: ld2410
has_target:
has_moving_target:
has_still_target:
out_pin_presence_status:
name: out pin presence status
button:
- platform: ld2410
factory_reset:
restart:
query_params:
select:
- platform: ld2410
distance_resolution:
name: "distance resolution"
baud_rate:
light_function:
out_pin_level:
name: out pin level
text_sensor:
- platform: ld2410
version:
mac_address:
number:
- platform: ld2410
timeout:
light_threshold:
name: light threshold
max_move_distance_gate:
name: max move distance gate
max_still_distance_gate:
name: max still distance gate
g0:
move_threshold:
name: g0 move threshold
still_threshold:
name: g0 still threshold
g1:
move_threshold:
name: g1 move threshold
still_threshold:
name: g1 still threshold
g2:
move_threshold:
name: g2 move threshold
still_threshold:
name: g2 still threshold
g3:
move_threshold:
name: g3 move threshold
still_threshold:
name: g3 still threshold
g4:
move_threshold:
name: g4 move threshold
still_threshold:
name: g4 still threshold
g5:
move_threshold:
name: g5 move threshold
still_threshold:
name: g5 still threshold
g6:
move_threshold:
name: g6 move threshold
still_threshold:
name: g6 still threshold
g7:
move_threshold:
name: g7 move threshold
still_threshold:
name: g7 still threshold
g8:
move_threshold:
name: g8 move threshold
still_threshold:
name: g8 still threshold
- platform: ld2410
light:
moving_distance:
still_distance:
moving_energy:
still_energy:
detection_distance:
g0:
move_energy:
name: g0 move energy
still_energy:
name: g0 still energy
g1:
move_energy:
name: g1 move energy
still_energy:
name: g1 still energy
g2:
move_energy:
name: g2 move energy
still_energy:
name: g2 still energy
g3:
move_energy:
name: g3 move energy
still_energy:
name: g3 still energy
g4:
move_energy:
name: g4 move energy
still_energy:
name: g4 still energy
g5:
move_energy:
name: g5 move energy
still_energy:
name: g5 still energy
g6:
move_energy:
name: g6 move energy
still_energy:
name: g6 still energy
g7:
move_energy:
name: g7 move energy
still_energy:
name: g7 still energy
g8:
move_energy:
name: g8 move energy
still_energy:
name: g8 still energy
Log:
INFO ESPHome 2024.9.1 INFO Reading configuration /config/esphome/d1minitc-mac2c43-ip3156.yaml… INFO Generating C++ source… INFO Compiling app… Processing d1minitc-mac-2c43-ip-31-56 (board: d1_mini; framework: arduino; platform: espressif8266) -------------------------------------------------------------------------------- HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash Dependency Graph |-- ESPAsyncTCP-esphome @ 2.0.0 |-- ESPAsyncWebServer-esphome @ 3.2.2 |-- DNSServer @ 1.1.1 |-- ESP8266WiFi @ 1.0 |-- ESP8266mDNS @ 1.2 |-- noise-c @ 0.1.6 |-- ArduinoJson @ 6.18.5 RAM: [===== ] 49.5% (used 40520 bytes from 81920 bytes) Flash: [====== ] 55.7% (used 581537 bytes from 1044464 bytes) Building .pioenvs/d1minitc-mac-2c43-ip-31-56/firmware.bin esp8266_copy_factory_bin([“.pioenvs/d1minitc-mac-2c43-ip-31-56/firmware.bin”], [“.pioenvs/d1minitc-mac-2c43-ip-31-56/firmware.elf”]) esp8266_copy_ota_bin([“.pioenvs/d1minitc-mac-2c43-ip-31-56/firmware.bin”], [“.pioenvs/d1minitc-mac-2c43-ip-31-56/firmware.elf”]) ========================= [SUCCESS] Took 10.67 seconds ========================= INFO Successfully compiled program. INFO Connecting to 192.168.31.56 INFO Uploading /data/build/d1minitc-mac-2c43-ip-31-56/.pioenvs/d1minitc-mac-2c43-ip-31-56/firmware.bin (585696 bytes) INFO Compressed to 396391 bytes ERROR Error receiving acknowledge chunk OK: timed out
