I’ve been trying to update my inovelli switches through ZHA’s OTA feature for a while and I haven’t been able to get anything to work. I followed the instructions here for both the config and manually running an update command to individual switches and they have all been unsuccessful with the same logs. Looking in the debug logs all I see is that the call to OTA update times out after 5 minutes. ZHA is blocked by this 5 minute call and ends up taking ~6 minutes to fully startup.
to see this log I run
cat home-assistant.log | egrep zigpy.ota\|zigpy.util\|zigpy.*OTA
with debug logging on
The call stack points to this file and specifically to the line where the OTA file is retrieved:
async with req.get(self.UPDATE_URL) as rsp:
I can load this url in my laptop’s browser fine fwiw.
Can anyone help me with why this is timing out or what I can do to get more verbose logging? I am relatively new to home assistant and have little experience debugging it. I even tried enabling other OTA providers and I would get a similar stack trace but at a different line corresponding to a different provider. I have a SONOFF coordinator on a very old raspberry pi 3.
My current versions are:
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2022.12.5",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.7",
"docker": true,
"arch": "aarch64",
"timezone": "America/Los_Angeles",
"os_name": "Linux",
"os_version": "5.15.76-v8",
"supervisor": "2022.11.2",
"host_os": "Home Assistant OS 9.4",
"docker_version": "20.10.19",
"chassis": "embedded",
"run_as_root": true
"versions": {
"bellows": "0.34.5",
"zigpy": "0.52.3",
"zigpy_deconz": "0.19.2",
"zigpy_xbee": "0.16.2",
"zigpy_znp": "0.9.2",
"zigpy_zigate": "0.10.3",
"zhaquirks": "0.0.89"
