OTBR 2.12.2 not starting
After updating OTBR from 2.12.1 to 2.12.2 it is not starting anymore. I am not sure if this is really due to OTBR itself or the HA update to 2024.12. It was working flawlessly before.
Ha itself is working normal. I thought asking here before restoring the backup to check which of the updates is causing the problem.
[13:11:56] INFO: The otbr-web is disabled.
s6-rc: info: service mdns: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service mdns successfully started
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service banner: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
[13:11:56] INFO: Starting mDNS Responder...
Default: mDNSResponder (Engineering Build) (Dec  3 2024 17:53:13) starting
 Add-on: OpenThread Border Router
 OpenThread Border Router add-on
 Add-on version: 2.12.2
 You are running the latest version of this add-on.
 System: Debian GNU/Linux 12 (bookworm)  (aarch64 / raspberrypi5-64)
 Home Assistant Core: 2024.12.1
 Home Assistant Supervisor: 2024.11.4
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service banner successfully started
s6-rc: info: service universal-silabs-flasher: starting
[13:11:57] INFO: Checking /dev/ttyUSB0 identifying Home Assistant Connect ZBT-1 from Nabu Casa.
[13:11:57] INFO: Starting universal-silabs-flasher with /dev/ttyUSB0
2024-12-08 13:11:58.027 RASPI-HA universal_silabs_flasher.flash INFO Extracted GBL metadata: NabuCasaMetadata(metadata_version=2, sdk_version='4.4.4', ezsp_version=None, ot_rcp_version='SL-OPENTHREAD/2.4.4.0_GitHub-7074a43e4' (2.4.4.0), cpc_version=None, fw_type=<FirmwareImageType.OPENTHREAD_RCP: 'openthread_rcp'>, fw_variant=None, baudrate=460800)
2024-12-08 13:11:58.027 RASPI-HA universal_silabs_flasher.flasher INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-12-08 13:12:05.147 RASPI-HA universal_silabs_flasher.flasher INFO Probing ApplicationType.SPINEL at 460800 baud
2024-12-08 13:12:09.806 RASPI-HA universal_silabs_flasher.flasher INFO Detected ApplicationType.SPINEL, version 'SL-OPENTHREAD/2.4.4.0_GitHub-7074a43e4' (2.4.4.0) at 460800 baudrate (bootloader baudrate None)
2024-12-08 13:12:09.806 RASPI-HA universal_silabs_flasher.flash INFO Firmware version 'SL-OPENTHREAD/2.4.4.0_GitHub-7074a43e4' (2.4.4.0) is flashed, not re-installing
s6-rc: info: service universal-silabs-flasher successfully started
s6-rc: info: service otbr-agent: starting
[13:12:10] INFO: Setup OTBR firewall...
[13:12:10] INFO: Starting otbr-agent...
[NOTE]-AGENT---: Running 0.3.0-b041fa52-dirty
[NOTE]-AGENT---: Thread version: 1.3.0
[NOTE]-AGENT---: Thread interface: wpan0
[NOTE]-AGENT---: Radio URL: spinel+hdlc+uart:///dev/ttyUSB0?uart-baudrate=460800&uart-flow-control
[NOTE]-AGENT---: Radio URL: trel://eth0
[NOTE]-ILS-----: Infra link selected: eth0
51d.16:34:49.602 [C] P-SpinelDrive-: Software reset co-processor successfully
51d.16:34:49.622 [C] Platform------: platformConfigureTunDevice() at netif.cpp:2022: Operation not permitted
[13:12:10] WARNING: otbr-agent exited with code 5 (by signal 0).
Chain OTBR_FORWARD_INGRESS (0 references)
target     prot opt source               destination
DROP       all  --  anywhere             anywhere             PKTTYPE = unicast
DROP       all  --  anywhere             anywhere             match-set otbr-ingress-deny-src src
ACCEPT     all  --  anywhere             anywhere             match-set otbr-ingress-allow-dst dst
otbr-ingress-deny-src-swap
otbr-ingress-allow-dst-swap
Chain OTBR_FORWARD_EGRESS (0 references)
[13:12:10] INFO: OTBR firewall teardown completed.
s6-svlisten1: fatal: /run/s6-rc/servicedirs/otbr-agent failed permanently or its supervisor died
s6-rc: warning: unable to start service otbr-agent: command exited 1
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service universal-silabs-flasher: stopping
s6-rc: info: service mdns: stopping
/run/s6/basedir/scripts/rc.init: warning: s6-rc failed to properly bring all the services up! Check your logs (in /run/uncaught-logs/current if you have in-container logging) for more information.
/run/s6/basedir/scripts/rc.init: fatal: stopping the container.
Default: mDNSResponder (Engineering Build) (Dec  3 2024 17:53:13) stopping
s6-rc: info: service universal-silabs-flasher successfully stopped
s6-rc: info: service banner: stopping
s6-rc: info: service banner successfully stopped
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
[13:12:10] INFO: mDNS ended with exit code 4 (signal 0)...
s6-rc: info: service mdns successfully stopped
[13:12:14] INFO: The otbr-web is disabled.
[13:12:14] INFO: Starting mDNS Responder...
[13:12:15] INFO: Checking /dev/ttyUSB0 identifying Home Assistant Connect ZBT-1 from Nabu Casa.
[13:12:15] INFO: Starting universal-silabs-flasher with /dev/ttyUSB0
2024-12-08 13:12:15.729 RASPI-HA universal_silabs_flasher.flash INFO Extracted GBL metadata: NabuCasaMetadata(metadata_version=2, sdk_version='4.4.4', ezsp_version=None, ot_rcp_version='SL-OPENTHREAD/2.4.4.0_GitHub-7074a43e4' (2.4.4.0), cpc_version=None, fw_type=<FirmwareImageType.OPENTHREAD_RCP: 'openthread_rcp'>, fw_variant=None, baudrate=460800)
2024-12-08 13:12:15.729 RASPI-HA universal_silabs_flasher.flasher INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-12-08 13:12:22.812 RASPI-HA universal_silabs_flasher.flasher INFO Probing ApplicationType.SPINEL at 460800 baud
2024-12-08 13:12:23.942 RASPI-HA universal_silabs_flasher.flasher INFO Detected ApplicationType.SPINEL, version 'SL-OPENTHREAD/2.4.4.0_GitHub-7074a43e4' (2.4.4.0) at 460800 baudrate (bootloader baudrate None)
2024-12-08 13:12:23.942 RASPI-HA universal_silabs_flasher.flash INFO Firmware version 'SL-OPENTHREAD/2.4.4.0_GitHub-7074a43e4' (2.4.4.0) is flashed, not re-installing
[13:12:24] INFO: Setup OTBR firewall...
[13:12:24] INFO: Starting otbr-agent...
51d.16:35:03.742 [C] P-SpinelDrive-: Software reset co-processor successfully
51d.16:35:03.763 [C] Platform------: platformConfigureTunDevice() at netif.cpp:2022: Operation not permitted
[13:12:24] WARNING: otbr-agent exited with code 5 (by signal 0).
[13:12:25] INFO: OTBR firewall teardown completed.
[13:12:25] INFO: mDNS ended with exit code 4 (signal 0)...
[13:12:30] INFO: The otbr-web is disabled.
[13:12:30] INFO: Starting mDNS Responder...
[13:12:31] INFO: Checking /dev/ttyUSB0 identifying Home Assistant Connect ZBT-1 from Nabu Casa.
[13:12:31] INFO: Starting universal-silabs-flasher with /dev/ttyUSB0
2024-12-08 13:12:32.082 RASPI-HA universal_silabs_flasher.flash INFO Extracted GBL metadata: NabuCasaMetadata(metadata_version=2, sdk_version='4.4.4', ezsp_version=None, ot_rcp_version='SL-OPENTHREAD/2.4.4.0_GitHub-7074a43e4' (2.4.4.0), cpc_version=None, fw_type=<FirmwareImageType.OPENTHREAD_RCP: 'openthread_rcp'>, fw_variant=None, baudrate=460800)
2024-12-08 13:12:32.082 RASPI-HA universal_silabs_flasher.flasher INFO Probing ApplicationType.GECKO_BOOTLOADER at 115200 baud
2024-12-08 13:12:39.196 RASPI-HA universal_silabs_flasher.flasher INFO Probing ApplicationType.SPINEL at 460800 baud
2024-12-08 13:12:43.854 RASPI-HA universal_silabs_flasher.flasher INFO Detected ApplicationType.SPINEL, version 'SL-OPENTHREAD/2.4.4.0_GitHub-7074a43e4' (2.4.4.0) at 460800 baudrate (bootloader baudrate None)
2024-12-08 13:12:43.855 RASPI-HA universal_silabs_flasher.flash INFO Firmware version 'SL-OPENTHREAD/2.4.4.0_GitHub-7074a43e4' (2.4.4.0) is flashed, not re-installing
[13:12:44] INFO: Setup OTBR firewall...
[13:12:44] INFO: Starting otbr-agent...
51d.16:35:23.640 [C] P-SpinelDrive-: Software reset co-processor successfully
51d.16:35:23.660 [C] Platform------: platformConfigureTunDevice() at netif.cpp:2022: Operation not permitted
[13:12:44] WARNING: otbr-agent exited with code 5 (by signal 0).
[13:12:44] INFO: OTBR firewall teardown completed.
[13:12:44] INFO: mDNS ended with exit code 4 (signal 0)...
Many thanks for hints:
I downgraded to 2.11.0 and OBTR is working again.
Looks like this problem has been raised on GitHub:
I downgraded OTBR to 2.11.0. It works again under supervised HA 2024.12.
To complete this thread: the combination of OTBR 2.12.2 and HA 2024.12.2 is OK.
