miloit
September 5, 2026, 9:14pm
1
Problem
I’m trying to configure OTBR in docker-compose via entrypoint to make it automatically bind to 0.0.0.0 instead of 127.0.0.1.
docker-compose.yml attempt:
entrypoint: ["/bin/bash", "-c", "sed -i 's/-a 127.0.0.1/-a 0.0.0.0/g' /etc/default/otbr-web; sed -i 's/127.0.0.1/0.0.0.0/g' /etc/default/otbr-agent; exec /app/etc/docker/border-router/setup-host --radio-url 'spinel+hdlc+uart:///dev/serial/by-id/...'"]
Result:
sed: can't read /etc/default/otbr-web: No such file or directory
setup-host loops indefinitely
container keeps restarting
Questions
Doesn’t /etc/default/otbr-web exist when entrypoint runs?
Is the file created later in the startup process?
Is setup-host the wrong entrypoint?
Should I use a different startup script?
Is there a better way?
Dockerfile RUN? Init script? Environment variable?
Current Workaround (works perfectly)
docker exec otbr sed -i 's/-a 127.0.0.1/-a 0.0.0.0/g' /etc/default/otbr-web
docker exec otbr service otbr-web restart
But this isn’t elegant. How do others handle this?
Does anyone have a working docker-compose setup with external port binding for OTBR?
Environment
openthread/otbr:latest
DietPi
ConBee II
network_mode: host
Here’s my docker-compose file;
otbr:
image: openthread/border-router:latest
container_name: otbr
restart: unless-stopped
network_mode: host
privileged: true
devices:
- /dev/serial/by-id/usb-SONOFF_SONOFF_Dongle_Plus_MG24_2690c8b8bdf5ef11841b96a29ed47d52-if00-port0:/dev/ttyUSB3
- /dev/net/tun:/dev/net/tun
volumes:
- /home/pi/docker/otbr/data:/data
environment:
OT_RCP_DEVICE: "spinel+hdlc+uart:///dev/ttyUSB3?uart-baudrate=460800"
OT_INFRA_IF: "eth0"
OT_THREAD_IF: "wpan0"
OT_LOG_LEVEL: "7"
OT_WEB_LISTEN_ADDR: "0.0.0.0"
OT_REST_LISTEN_ADDR: "0.0.0.0"
A lot of older docu suggested you use OTBR_WEB_LISTEN or similar, but my container seems to work fine. Or well, it’s at least reachable on the ports and interfaces I want. I still haven’t managed to get the whole matter/thread malarkey working due to … networking issues? (even though everything is reachable from any device that should matter, it always ends up stalling at the last hurdle of actually commissioning a device to the OTBR server network and I’ve got no hair left to pull so).
You posted this exact question to another thread (not recommended). See my answer there .
Short answer: it depends on what docker image you’re using, but you did not specify yours.
