Other log error....... Need help
Logger: homeassistant.components.notify
Source: components/smtp/notify.py:141
Integration: Notifications (documentation, issues)
First occurred: 12:18:39 PM (1 occurrences)
Last logged: 12:18:39 PM
Error setting up platform smtp
  File "/usr/src/homeassistant/homeassistant/components/notify/legacy.py", line 93, in async_setup_platform
    notify_service = await hass.async_add_executor_job(
  File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 100, in get_service
    if mail_service.connection_is_valid():
  File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 162, in connection_is_valid
    server = self.connect()
  File "/usr/src/homeassistant/homeassistant/components/smtp/notify.py", line 141, in connect
    mail = smtplib.SMTP_SSL(
  File "/usr/local/lib/python3.11/smtplib.py", line 1050, in __init__
    SMTP.__init__(self, host, port, local_hostname, timeout,
  File "/usr/local/lib/python3.11/smtplib.py", line 255, in __init__
    (code, msg) = self.connect(host, port)
  File "/usr/local/lib/python3.11/smtplib.py", line 341, in connect
    self.sock = self._get_socket(host, port, self.timeout)
  File "/usr/local/lib/python3.11/smtplib.py", line 1057, in _get_socket
    new_socket = self.context.wrap_socket(new_socket,
  File "/usr/local/lib/python3.11/ssl.py", line 517, in wrap_socket
    return self.sslsocket_class._create(
  File "/usr/local/lib/python3.11/ssl.py", line 1075, in _create
    self.do_handshake()
  File "/usr/local/lib/python3.11/ssl.py", line 1346, in do_handshake
    self._sslobj.do_handshake()
ssl.SSLError: [SSL: WRONG_VERSION_NUMBER] wrong version number (_ssl.c:1002)
My crystal ball tells me you have to tighten the screws under your bathroom sink :tired_face:
My eyes tell me you have an issue with your SMTP notifier, likely using a wrong encryption setting
That is what I don’t understand: I had issues with the SMTP Integration and (believed that) I deleted it and added instead the Google Mail Integration. The SMTP Integration no longer shows in list of Integrations but I see it in YAML ( I am not comfortable/proficient with YAML ). Could it be that what I see in YAML is in fact the Google Mail Integration and not the (supposedly deleted) SMTP Integration ?
As much as I can see the Google Mail Integration works fine.
The “list of integrations” are the integrations configured through the UI.
The ones configured in YAML, as is the case here, apparently, do not show there.
