Out of memory error (in browser)
On one of my home assistant I get this error pretty frrequently. I reload the browser and then its fine, but after few minutes the browser crashes agail, with this error
Also while browsing the various home assistant tabs, the navigation is less smooth then usual, some freezes.
What can it be?
Probably a custom dashboard card with a memory leak.
Hi!
I noticed completely the same issue after upgrade of HA to version 2024.3 (from version 2023.12). Browser crashes almost everyday, I did not change my dashboard, only upgrade of HA made the diffrerence.
BR
Greg
None of this makes any sense. Home Assistant and your browser are on separate computers.
But the update somhow created a memory leak to a dashboard card. I have this problem as well. I have way too many custom cards to isolate. Ended up installing a browser auto refresher to temporarily fix this issue for now.
In your web browser right click anywhere in the page and choose “inspect”, look at the console log for errors.
In my case was card-mod lovelace addon
This was it for me too. I don’t even use it, I just had it installed. Been running out of memory for months. Tried tons of stuff, Incognito in Chrome, then recently “Guest” mode in Chrome for absolutely 0 browser extensions, and it would still run out of memory.
I uninstalled card-mod, refreshed with Ctrl+F5 (critical, otherwise it’s still loaded, as you see in the developer tools console), and now it’s been running for days.
I did have mine installed as a “frontend module” as explained here: GitHub - thomasloven/lovelace-card-mod: 🔹 Add CSS styles to (almost) any lovelace card
With:
frontend:
  extra_module_url:
    - /hacsfiles/lovelace-card-mod/card-mod.js
In my configuration.yaml
I had nothing using it across any of my dashboards however.
Maybe card-mod.js isn’t the only problem.
When I leave an HA tab open on the Zigbee2MQTT addon it happens too!
The tab starts with 90MB of used memory and a few hours later it ends up with > 4GB and Chrome crashes.
This is what I see in the console:
