I am running HA Supervised on a rPi4. ALL of this stuff is BRAND NEW to me. I am trying to clear up space, as I’m now at capacity. I’ve tried following all kinds of guides to purge the logs. I couldn’t really even tell you if that has been done successfully – but it has been done. I’ve deleted backups. And I’m still at 95%.
I ran this command below to get a feel for the space being eaten up, but it really doesn’t mean anything to me. Maybe it does to you?
This is just info from whatever you installed on the Pi.
It shows that the mmc mount is 100% full, but that may not be just HA i dont know what else you installed and how?
Supervised installation is for you know what you are doing and the onus is on you keep everything running smoothly.
The better option for now would be HOAS install. Dont forget to make a backup first you can then import.
I installed via the only method I could figure out. I knew I wanted to keep the Pi available to run other light programs rather than have only the HAOS and it be dedicated to that.
In other news, I learned another command that let me go deeper in auditing the space on the card, and discovered that the backup actually WASN’T deleted. So, that ended up doing the trick!
