Outdoor Lights — Sunset Fade-in / Overnight Fade-out (color, brightness, durations + summer-skip gate)
A blueprint that drives a light (or light group) through a gentle daily cycle:
  1. Sunset — fade gradually from 1% up to your target brightness
  2. Late evening — fade gradually back down to 1%
  3. Just after — hard-off
Color holds at a single configurable RGB value the whole time. Default is warm amber (255, 147, 41) — roughly 2200K, a candle / old sodium-streetlight feel that's easy on the eyes and good for outdoor accent lighting.
Import
Or paste this URL into Settings → Automations & Scenes → Blueprints → Import Blueprint:
https://magikh0e.pl/pubHomeAutomation/blueprints/outdoorLightsSunsetFade.yaml.txt
The HA quirk it solves
A transition: on a light that's currently off doesn't animate — it snaps straight to the target brightness. The blueprint works around it with a two-step turn-on:
  • Call 1: brightness_pct: 1, no transition → establishes the "on" state
  • 5-second settle
  • Call 2: brightness_pct: <target> with the full transition → the actual animated fade-in
The fade-out side doesn't need the trick (the light's already on, so a single transition from any non-off state works). If you've ever wondered why your sunrise/sunset fades "jump" instead of ramping, this is why.
What's configurable
Light
  • Light or light group entity (use a light: - platform: group for synchronised multi-bulb setups)
  • Color (RGB) — defaults to warm amber
  • Target brightness — defaults to 50%
Sunset fade-in
  • Sunset trigger offset (e.g. -00:20:00 = 20 min before astronomical sunset)
  • Fade-in duration — default 1800s (30 min)
  • Optional "skip when the sky is still bright" gate — uses sun elevation, so high-summer evenings where astronomical sunset fires while it's still bright outside don't kick the lights on early. Configurable elevation threshold.
Late-evening fade-out
  • Fade-out start time — default 23:30
  • Fade-out duration — default 1800s (30 min)
  • Hard-off time — default 00:00 (set to fade-out start + duration, or a touch later)
Sensible guards built in: the fade-out branch skips if the light's already off (so it doesn't turn a manually-off light back on at 1%), and the elevation gate has a | float(99) fallback so a momentary sun.sun attribute blip can't silently swallow the trigger.
Full blueprint YAML
blueprint:
  name: Outdoor Lights — Sunset Fade-in / Overnight Fade-out
  description: >
    Drives a light or light group through a daily sunset-to-midnight cycle:
    fade in at sunset, fade out at a configurable late-evening time, hard-off
    at a configurable post-fade time. Configurable color, brightness, durations,
    sunset offset, and an optional sun-elevation gate so high-summer evenings
    don't kick the lights on while it's still bright outside.
  domain: automation
  source_url: https://magikh0e.pl/pubHomeAutomation/blueprints/outdoorLightsSunsetFade.yaml.txt
  input:
    light_section:
      icon: mdi:lightbulb-on-outline
      input:
        light_entity:
          name: Light or light group
          description: >
            Single light entity, or a `light: - platform: group` that combines
            multiple bulbs into one logical entity.
          selector:
            entity:
              filter:
                - domain: light
        rgb_color:
          description: >
            Color used throughout the cycle. Default 255,147,41 = warm amber.
          default: [255, 147, 41]
          selector:
            color_rgb:
        target_brightness_pct:
          name: Target brightness (%)
          description: Brightness reached at the end of the fade-in.
          default: 50
          selector:
            number:
              min: 1
              max: 100
              step: 1
              unit_of_measurement: "%"
              mode: slider
    fade_in_section:
      icon: mdi:weather-sunset-down
      input:
        sunset_offset:
          name: Sunset trigger offset
          description: "Negative = earlier, positive = later. Format HH:MM:SS."
          default: "00:00:00"
          selector:
            text:
        fade_in_seconds:
          name: Fade-in duration (seconds)
          description: "Ramp time from 1% to target. Default 1800 = 30 min."
          default: 1800
          selector:
            number:
              min: 1
              max: 3600
              step: 1
              unit_of_measurement: "s"
              mode: box
        require_dark:
          name: Skip when the sky is still bright
          description: >
            Optional gate: only run the fade-in if the sun's elevation is below
            the threshold below.
          default: false
          selector:
            boolean:
        dark_elevation:
          name: Dark-sky elevation threshold (degrees)
          description: "Default 3°. Lower (-3° to 0°) waits for proper darkness."
          default: 3
          selector:
            number:
              min: -20
              max: 20
              step: 0.5
              unit_of_measurement: "°"
              mode: slider
    fade_out_section:
      icon: mdi:weather-night
      input:
        fade_out_time:
          name: Fade-out start time
          description: "When the lights start dimming down. Default 23:30."
          default: "23:30:00"
          selector:
            time:
        fade_out_seconds:
          name: Fade-out duration (seconds)
          description: "Ramp time back down to 1%. Default 1800 = 30 min."
          default: 1800
          selector:
            number:
              min: 1
              max: 3600
              step: 1
              mode: box
        turn_off_time:
          description: >
            Issues a hard light.turn_off after the fade-out. Default 00:00.
            Set to fade-out time + duration, or slightly later.
          default: "00:00:00"
          selector:
            time:
mode: single
max_exceeded: silent
  - platform: sun
    event: sunset
    offset: !input sunset_offset
  - platform: time
    at: !input fade_out_time
  - platform: time
    at: !input turn_off_time
variables:
  require_dark: !input require_dark
  dark_elevation: !input dark_elevation
  - choose:
      # Branch 1: SUNSET FADE-IN
      - conditions:
          - condition: trigger
          - condition: template
            value_template: >-
              {{ not require_dark
                 or is_state('sun.sun', 'below_horizon')
                 or (state_attr('sun.sun', 'elevation') | float(99) < dark_elevation) }}
        sequence:
          - action: light.turn_on
              entity_id: !input light_entity
              brightness_pct: 1
              rgb_color: !input rgb_color
          - delay:
              seconds: 5
              brightness_pct: !input target_brightness_pct
              transition: !input fade_in_seconds
      # Branch 2: LATE-EVENING FADE-OUT
      - conditions:
          - condition: state
            state: "on"
        sequence:
              brightness_pct: 1
              transition: !input fade_out_seconds
      # Branch 3: HARD-OFF AFTER FADE-OUT
      - conditions:
        sequence:
          - action: light.turn_off
Companion guide
There's a longer write-up with a three-stage step-fade variant (20% → 60% → 100% across the first hour, instead of one smooth ramp), a color reference with RGB values for cool-white / coral / security-white / garden-green, and a troubleshooting table for the usual snags (location not set, transitions not honoured, bulbs that won't go below a brightness floor):
Feedback / improvements welcome — happy to fold fixes back in.
