This blueprint handles turning outdoor lights on at dusk and off at dawn.
Features
- Turn lights on at sunset and off at sunrise
- Set offsets for sunset/sunrise (for example, turn lights on a half-hour after sunset and off a half-hour before sunrise)
- Specify a fixed time for turning lights on or off (vs. using sunset/sunrise)
- Turn lights off in the middle of the night during spring and fall bird migration periods
- Ability to set all parameters vs. using defaults (e.g., different migration date periods, etc.)
Inputs
- One or more devices to control.
- The blueprint allows selecting devices from either the Light or Switch domains.
- The actions used are homeassistant.turn_on and homeassistant.turn_off.
- Type of trigger for turning on lights:
- Sunset (default)
- Fixed Time
- Type of trigger for turning off lights:
- Sunrise (default)
- Fixed Time
- Optional offsets for sunrise and sunset in format HH:MM:SS which can be negative
- Migration override switch
If set, the lights are turned off during critical night time hours and following inputs apply:- Override lights off time (defaults: 11PM)
- Override lights on time (defaults: 6AM)
- Migration periods start and end:
- Spring period start month and day (default: March 1)
- Spring period end month and day (default: June 15)
- Fall period start month and day (default: August 15)
- Fall period end month and day (default: November 30)
The date ranges and override times are based on the Lights Out Texas program. The ability to override date ranges is provided so you can adjust based on your own local circumstances or to target the defined critical peak periods vs. the full migration periods.
For more information on Lights Out Texas, click here.
NOTE: Existing code doesn’t check that the end of the migration override time frame is before sunrise (adjusted by offset). If the turn-on time at the end of the migration override occurs after local sunrise/offset, it could result in the lights being on all day. A check for this is on my list of potential enhancements.
Github Gist: Outdoor Night Lighting Control with Migration Overrides
Change Log
- 2024-08-30: Initial release
- 2024-09-03: Streamlined migration season template code
Source Code
blueprint:
name: Outdoor Night Lighting Control with Migration Overrides
description: >
Control outdoor lights with options for on at sunset and off at sunrise (with optional offsets), or at fixed times, and bird migration overrides.
- By default, lights are turned on at sunset and turned off at sunrise. If an offset is specified (positive or negative), that is applied to either the sunset or sunrise time.
- As an alternative to using sunset or sunrise, lights can be turned on and/or off at a fixed time.
- During the specified date ranges for spring and fall bird migration periods, lights are turned off at 11pm and turned on at 6am. The date ranges and the override off/on times can be changed. In addition, the override feature can be turned off.
The date ranges and override times are based on the **Lights Out Texas** program. The ability to override date ranges is provided so you can adjust based on your own local circumstances.
For more information on **Lights Out Texas**, [click here.](https://texanbynature.org/projects/lights-out-texas/)
Release date: 2024-09-03
domain: automation
source_url: https://gist.github.com/NateEaton/261ff8d0a88dd74263b980c0725d91f6
# Which devices to control
input:
lights:
description: Select one or more outdoor lights to control. Device domain options include lights and switches.
selector:
entity:
- domain:
- light
- switch
# How to turn lights on
lights_on_trigger_section:
name: Turn On at Sunset or Fixed Time
icon: mdi:weather-sunset
description: Options for using sunset or fixed time as a trigger to turn lights on
collapsed: true
input:
lights_on_trigger_type:
name: Lights On Trigger Type
description: Choose whether to use sunset or a fixed time to turn lights on
default: sunset
selector:
select:
options:
- label: Sunset
value: sunset
- label: Fixed Time
value: fixed_time
offset_sunset:
name: Offset Before/After Sunset
description: 'Time offset before or after sunset to turn lights on (hh:mm:ss, can be negative)'
default: 00:00:00
selector:
text:
multiple: false
multiline: false
fixed_on_time:
name: Fixed Time to Turn Lights On
description: 'Fixed time to turn lights on (format: hh:mm:ss)'
default: '20:00:00'
selector:
time: {}
# How to turn lights off
lights_off_trigger_section:
name: Turn Off at Sunrise or Fixed Time
icon: mdi:weather-sunset-up
description: Options for using sunrise or fixed time as a trigger to turn lights off
collapsed: true
input:
lights_off_trigger_type:
name: Lights Off Trigger Type
description: Choose whether to use sunrise or a fixed time to turn lights off
default: sunrise
selector:
select:
options:
- label: Sunrise
value: sunrise
- label: Fixed Time
value: fixed_time
offset_sunrise:
name: Offset Before/After Sunrise
description: 'Time offset before or after sunrise to turn lights off (hh:mm:ss, can be negative)'
default: 00:00:00
selector:
text:
multiple: false
multiline: false
fixed_off_time:
name: Fixed Time to Turn Lights Off
description: 'Fixed time to turn lights off (format: hh:mm:ss)'
default: '20:00:00'
selector:
time: {}
# Whether and how to override lights during migration periods
migration_override_section:
icon: mdi:bird
description: Options for migration overrides
collapsed: true
input:
migration_override:
description: Enable or disable migration override
default: true
selector:
boolean: {}
migration_override_off_time:
name: Migration Override Lights Off Time
description: Time to turn lights off during migration
default: '23:00:00'
selector:
time: {}
migration_override_on_time:
name: Migration Override Lights On Time
description: >
Time to turn lights back on during migration.
CAUTION: if sunrise is before 6am then this could result in leaving lights on all day (i.e., the trigger associated with this happening after the trigger to turn lights on at runrise.)
Consider setting this to just before earliest sunrise time in your area (also accounting for any offset you've set).
default: 06:00:00
selector:
time: {}
spring_migration_start_month:
name: Spring Migration Start Month
description: Start month for spring migration
default: March
selector:
select:
options:
- January
- February
- March
- April
- May
- June
- July
- August
- September
- October
- November
- December
multiple: false
custom_value: false
sort: false
spring_migration_start_day:
name: Spring Migration Start Day
description: Start day for spring migration
default: 1
selector:
number:
min: 1.0
max: 31.0
mode: box
step: 1.0
spring_migration_end_month:
name: Spring Migration End Month
description: End month for spring migration
default: June
selector:
select:
options:
- January
- February
- March
- April
- May
- June
- July
- August
- September
- October
- November
- December
multiple: false
custom_value: false
sort: false
spring_migration_end_day:
name: Spring Migration End Day
description: End day for spring migration
default: 15
selector:
number:
min: 1.0
max: 31.0
mode: box
step: 1.0
fall_migration_start_month:
name: Fall Migration Start Month
description: Start month for fall migration
default: August
selector:
select:
options:
- January
- February
- March
- April
- May
- June
- July
- August
- September
- October
- November
- December
multiple: false
custom_value: false
sort: false
fall_migration_start_day:
name: Fall Migration Start Day
description: Start day for fall migration
default: 15
selector:
number:
min: 1.0
max: 31.0
mode: box
step: 1.0
fall_migration_end_month:
name: Fall Migration End Month
description: End month for fall migration
default: November
selector:
select:
options:
- January
- February
- March
- April
- May
- June
- July
- August
- September
- October
- November
- December
multiple: false
custom_value: false
sort: false
fall_migration_end_day:
name: Fall Migration End Day
description: End day for fall migration
default: 30
selector:
number:
min: 1.0
max: 31.0
mode: box
step: 1.0
# Lights on triggers
- platform: sun
event: sunset
offset: !input offset_sunset
- platform: time
at: !input fixed_on_time
# Light off triggers
- platform: sun
event: sunrise
offset: !input offset_sunrise
- platform: time
at: !input fixed_off_time
# Migration override triggers
- platform: time
at: !input migration_override_off_time
- platform: time
at: !input migration_override_on_time
variables:
# Needed to use inputs in template logic
lights_on_trigger_type: !input lights_on_trigger_type
lights_off_trigger_type: !input lights_off_trigger_type
migration_override: !input migration_override
migration_override_on_time: !input migration_override_on_time
offset_sunrise: !input offset_sunrise
spring_migration_start_month: !input spring_migration_start_month
spring_migration_start_day: !input spring_migration_start_day
spring_migration_end_month: !input spring_migration_end_month
spring_migration_end_day: !input spring_migration_end_day
fall_migration_start_month: !input fall_migration_start_month
fall_migration_start_day: !input fall_migration_start_day
fall_migration_end_month: !input fall_migration_end_month
fall_migration_end_day: !input fall_migration_end_day
in_migration_season: >-
{% set month_mapping = {
"January": 1, "February": 2, "March": 3, "April": 4, "May": 5, "June": 6,
"July": 7, "August": 8, "September": 9, "October": 10, "November": 11, "December": 12
{% set n = now() %}
{% set spring_start = n.replace(month=month_mapping[spring_migration_start_month],
day=spring_migration_start_day) %}
{% set spring_end = n.replace(month=month_mapping[spring_migration_end_month],
day=spring_migration_end_day) %}
{% set fall_start = n.replace(month=month_mapping[fall_migration_start_month],
day=fall_migration_start_day) %}
{% set fall_end = n.replace(month=month_mapping[fall_migration_end_month],
day=fall_migration_end_day) %}
{% if (spring_start <= n <= spring_end) or (fall_start <= n <= fall_end) %}
true
{% else %}
false
{% endif %}
- choose:
- conditions:
# Turn on lights if sunset trigger set
- condition: trigger
- condition: template
value_template: '{{ lights_on_trigger_type == "sunset" }}'
sequence:
- action: homeassistant.turn_on
target: !input lights
- conditions:
# Turn on lights if fixed time trigger set
value_template: '{{ lights_on_trigger_type == "fixed_time" }}'
sequence:
- conditions:
# Turn off lights if sunrise trigger set
value_template: '{{ lights_off_trigger_type == "sunrise" }}'
sequence:
- action: homeassistant.turn_off
- conditions:
# Turn off lights if fixed time trigger set
value_template: '{{ lights_off_trigger_type == "fixed_time" }}'
sequence:
- conditions:
# Turn lights off during migration season
value_template: '{{ in_migration_season }}'
sequence:
- if:
# Only execute if override is enabled during migration season
value_template: '{{ migration_override }}'
then:
- conditions:
# Turn lights back on during migration season
sequence:
- if:
# Future enhancement idea: only execute if migration_override_on_time is earlier
# than sunrise (adjusted with offset) or the specified fixed off time.
then:
mode: single
