Hi there. I need a device that informs me when a pond / rain water tank / etc drops below a specific water level. I first thought about a water level device, but there do not seem to be affordable and/or devices without tinkering
Now I was thinking about simply attaching a water leak sensor (like Aqara), attach it at the desired height and simply create an automation on “if no water leak detected”.
Only thing is: The IP Rating does not indicate that this device should be under water all of the time.
Is there any other HASS-Compatible device that offers that functionality? Preferably Zigbee? Maybe attaching wires to the screws of the Aqara (and putting the sensor itself into a waterproof case) should work? Anyone ever tried that?
In addition: If a leak is detected does the device go amok? Keeping pushing notifications and draining (no pun intended) the batttery or is the batterylife with water detected as good as with no water detected?
I got a tuya zigbee water leak sensor off eBay which has a long probe on a cord for little money. Had the sensors remote probe constantly submerged with little issue; bit of rust.
I know this is an old post but I’ve actually recently been working on exactly that kind of thing. It’s called Aqua-Node, a small, permanently sealed, cell-service-based, hubless, waterproof sensor you can stick inside/outside and set at whatever height you want. If the water reaches it, it’ll send you a text or email right away.
You can then look at custom settings for making audible noise from your phone when it receives a notifciation from a specific phone number.
Built to live outside in the sun/rain and goes off when the water actually hits the sensor (or the reverse if you want to know when the water recedes again).
It’s under development, but it will be seal-less (permanently enclosed) so completely waterproof, battery should last for years, signal can be sent via wifi or cell (cell service will be included).
Made for flood-prone spots like driveways, yards, and low streets
Check out the website! I am trying to gauge interest, so please sign up if you like the look of it
